1991 350 TPI Injectors not pulsing
Old Jun 12, 2018 | 09:28 AM
RandyNJ's Avatar
Car has sat for about three years. It was starting and running, but ran horribly jumping all around. Brought it to a shop and had a tune-up done. Drove it home and everything was okay, but a few hours after it wasn't going above 30mph full throttle and rpms weren't going up. It started running horribly and began stalling out. Brought it back to the shop and they tried numerous things with no solution.
Tried the following;-ecu (twice)-distributor -fuel relay switchHad fuel pressure the entire time. No injectors are pulsing. Tried looking around for a solution, anyone have suggestions?
Old Jun 12, 2018 | 10:45 AM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
Re: 1991 350 TPI Injectors not pulsing
This is just a guess but assuming that your fuses are ok, check the grounding toward the ECU. Has to be either in that or the other end of the fuses toward the ignition. You will need a volt/ohm meter.
Old Jun 12, 2018 | 11:29 AM
RandyNJ's Avatar
Will see if that helps anything... Completely lost as to what the problem may be. Last resort is bringing it to GM
Old Jun 12, 2018 | 11:38 AM
x55Cam's Avatar
Engine: 5.7L
Also assuming of course that the shop measured constant fuel pressure when accelerating/revving the motor?
Old Jun 12, 2018 | 11:48 AM
RandyNJ's Avatar
Not exactly sure, but I was told it never once lost fuel pressure. Also, the car will still start on starting fluid stalling after a few minutes/running horribly. I assume fuses were checked by the shop since they said they literally tried everything. I've read if one injector is bad it may cause the others to not pulse. Asked the shop about that and was told they couldn't check each injector separately because none of them are pulsing
Old Jun 12, 2018 | 11:58 AM
x55Cam's Avatar
Engine: 5.7L
yes, one injector having a shorted coil could possibly affect those others in the same bank. You can easily check that by removing the connector to each one and use an ohm meter. Should get a reading well above 10 ohms.
Old Jun 12, 2018 | 12:46 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
What x55 posted, the stock OEM Multec injectors are a known failure point. The coils start to short out and the ECM can't drive any of them.
Only fix is to replace them.
RBob.
Old Jun 12, 2018 | 04:16 PM
RandyNJ's Avatar
RBob.
If that's the issue do you have any recommendation for replacement injectors? Not looking to spend an outrageous amount, but don't necessarily want to replace them again anytime soon.
Old Jun 12, 2018 | 04:19 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Use the bosch, check with South Bay, they're members here.
Same problem with my 91 Z28, swapped them and problem solved.
Old Jun 12, 2018 | 07:44 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
I recommend this also. I did in my car as replacements for stock (which were only 85k old), and in the truck as well when I converted it to TPI. People say that you'll have to burn a new chip tweaked for the injectors, but I never had to do that. Fuel trims look fine in both vehicles.
Old Jun 12, 2018 | 09:02 PM
ULTM8Z's Avatar
yeah it seems to be hit or miss in terms of people needing tuning after Bosch III swap. But either way you end up with a far superior injector in the end... even if you need a tune it's very simple and well worth it.
Old Jun 13, 2018 | 05:45 AM
PurelyPMD's Avatar
Engine: LB9
Mine didn't need a tune - injectors are a little noisy but if you don't mind the clicking noise, you're fine.
Old Jun 19, 2018 | 01:46 PM
RandyNJ's Avatar
After calling around trying to find the best shop for the price to change injectors they all tell me they don't think it's injectors that they want to look the car over. One shop also said $600 labor at $100/hr which seems outrageous. Read around a bit and it seems 4 hours is reasonable for changing injectors? Does anyone know what else commonly causes injectors to not pulse other than a bad injector? Also, how long would it take for the injectors to be changed?
Old Jun 19, 2018 | 01:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Have you ohmed the injectors ?
Changing them is not that hard. 4 hours is too much labor time. Even if your slow I can’t imagine more than two hours. Get a t40 and 10mm socket and wrench and have at it.
Contact southbay08 (southbayfuel injectors.com )
For a great deal on injectors it sounds like you might need them.
Old Jun 19, 2018 | 01:54 PM
Engine: Lb9
Transmission: M20
https://www.southbayfuelinjectors.co...8-bosch-d3-tpi
https://www.southbayfuelinjectors.co...tors-1986-1992
Old Jun 19, 2018 | 01:59 PM
Engine: Lb9
Transmission: M20
Old Jun 19, 2018 | 02:25 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
While at it, do injector balance test also. The tester is cheap from ebay.
Old Jun 19, 2018 | 02:58 PM
PaulyC's Avatar
Why don't you disconnect all of them, that will rule out one of them taking out the bunch. Then you can connect a noid light and then crank it over and see if either bank fires. If they do that can rule out the ECU.
Old Jun 29, 2018 | 09:53 PM
RandyNJ's Avatar
So I brought the car to a different shop than the last since they literally told me they didn't know what was wrong... This shop says the fuel pump and fuel lines are bad. On startup you can hear the fuel pump come on, could the fuel pump still be bad? Also, I was told around $700 for the pump, lines, and labor. Does that sound right?
Old Jun 29, 2018 | 10:01 PM
Engine: Lb9
Transmission: M20
Doesn’t sound like you have listened to any advice on the previous threads. On another thread a member was quoted $500 for a pump replacement. I’d do it yourself the hardest part is the exhaust being in the way.
Old Jun 30, 2018 | 02:09 PM
GeneralDisorder's Avatar
Yes the pump could be bad. $700 is in the ball park with parts and labor. Very typical.
You really ought to look into doing some of this stuff yourself. Shops are going to rape you over working on something this old. Virtually this entire forum is for people that want/need to do that because shops are too expensive for the value of these cars. And god help you if you have corrosion problems on a 30 year old car. At my shop I have seriously considered adding a $5/Hr rider for every year older than 15 years just due to A: corrosion and hard to source parts, and B: previous buggery from owners or other shops that are clueless.
GD
Old Jun 30, 2018 | 06:28 PM
x55Cam's Avatar
Engine: 5.7L
If you are handy with an volt/ohm meter and have access to one, you should at the very least, disconnect all the injectors from the harness and measure across the coils. Very simple and very revealing as to where to go from that point. All it takes is for one bad/shorted one to cause major problems.
Irockirocs
Jun 4, 2012 05:05 PM
TPI84TRANSAM
Dec 6, 2009 06:23 AM
Hoss50
Dec 16, 2003 07:28 PM
Zepher
Sep 21, 2003 11:38 PM
