92 Camaro rs. Shifting problem. Help!
Old Jul 25, 2018 | 03:06 PM
Kinggparmer's Avatar
This is my son's car and he starts back to school in just over a week. Anyway. It's a 305 with a automatic. Everything is great in 1st and 2nd gear in OD ,after that it just revs up but no acceleration. Unless of course I drop back down to 2nd gear. Even if I drop it in manually jnto 1st or 2nd same thing. Any suggestions ? Torque converter or tranny issue? I'm really hoping someone has this exact problem that knows what it is before I end up replacing everything. Any help is greatly appreciated .
Old Jul 25, 2018 | 10:45 PM
BadHabit's Avatar
Car: 1989 TPI Formula, 1984 MCSS
Re: 92 Camaro rs. Shifting problem. Help!
Check fluid level. (running, hot, in park)
Clean & red or dark and burnt smelling?
Old Jul 26, 2018 | 05:59 AM
That's the first thing I checked. It was a little low and I added more fluid .Looked pretty clean and red. Didn't smell anything unusual.
Old Jul 26, 2018 | 06:48 AM
OrangeBird's Avatar
Car: 1989 Firebird
Really the only thing external to the transmission that could cause that kind of shifting troubles is the throttle valve cable . If it's stuck in the wide open throttle position that could cause no 3rd or 4th gear , but beyond that it would be something internal . Like the 3/4 clutch pack (rebuild the transmission at that point) or if you got really lucky maybe a valve body or accumulator problem . The throttle valve itself (in the valve body) has been known to stick in the WOT position if the gas pedal is stomped on hard enough , so if the throttle valve cable checks out the valve itself would be a good next thing to check .
PS , if you ask the mods to move your thread to the "transmissions/drivetrain" area rather than the "tech/engine" area where you posted it , there are lots of transmission savvy folks who would see it there and hopefully offer more in depth suggestions ...
R/T-Z28
Mar 3, 2013 06:17 PM
GASGZLR
Mar 10, 2004 03:04 PM
92GTA
Dec 7, 2002 03:33 PM
shaocaholica
Oct 14, 2002 01:22 PM
