need help with a missing 383 build pls
Old Aug 27, 2018 | 02:53 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I just built the engine last winter and just spent 2 months installing it
no codes I got 10kms on it idels fine
as soon as you go to accel just a bit it misses 1 or 2 cylinders
I have brand new 8mm wires
brand new cap and rotor today did nothing
new plugs with new alum heads I got
is making me crazy
this is a 10.5 comp 383
and it sould ne running amzing
not horrible
I have checked the firing order 4 times in the last week
the one thing I did was I know the timing was set to 7 to 8ish
and I had the chip burner guy burn me a chip
it feels like its missing when you go 1/4 throttle
and im about to go to a boost leak test just to see if I can hear a vacuum leak anywhere
don't have a cat either
can my valves be adjusted to tight causing missing
or just no power
the only thing I did was bypass delete my fuel filter sat and it helped a lot I can actually accel now
I have new 30lb inj that where brand new rebuilt I got on ebay
should I take the plugs out and inspect them
and should I do a compression test????
does anyone know if my valves are to tight would cause no power
maybe my fuel pump is old and dying
pls anything guys
im lost scratching my head
Old Aug 27, 2018 | 03:08 PM
Abubaca's Avatar
Re: need help with a missing 383 build pls
Was it running fine to begin with, and this problem is new, or has it been doing it all along? ....once you get past 1/4 throttle does it run ok, are does it feel bad at everything beyond 1/4 throttle? ...is the tune done via mailorder, or was it dyno tuned/street tuned in person?
Old Aug 27, 2018 | 03:22 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
vacuum leak, not enough octane and maybe just detonation. Try some octane boost if that doesn't help look for a vacuum leak or a loose plug wire.
Old Aug 27, 2018 | 03:41 PM
Abubaca's Avatar
What kind of intake? TPI/Multiport? TBI/throttle body based?
Check your fuel pressure and watch what it does while running....and when you run into that rough spot. Should stay fairly constant, but slowly rise with RPMs. It'll always fluctuate a little, but if it's TPI based, you'll want about 42 or 43 at WOT and mid 30s at idle. Again, they're all slightly different at idle, but if you're at low 30s or lower....and pressure doesn't rise as throttle is applied, that's definitely a fuel problem. 30 pound injectors are probably ok, but even if they're a tad small, they should be MORE than enough to handle normal driving duties, and at WOT, they'll probably be just a little over 80% duty cycle, which is about as high as you wanna push em. Stock original pump could easily be the problem, or at the very least, could easily be a problem in the future, even if it's not THIS problem.
Old Aug 27, 2018 | 03:56 PM
bensbaby's Avatar
Engine: 383 built
my chip was mailorder
it was running with my 305 tpi t5 it ran amazing
that's why I did the swap
I have had the car im my family since brand new 305 t5 88gta
now its a 383 t56
1/4 up throttle it just misses and cuts out
I am still breaking the engine 10kms on it
it has 91 gas that's all I have here
tpi with the 305 but now I have a stealth ram intake and stock tb
I have a 44psi adjustable aem fpr with a gauge
and I have a wideband 02 in a gauage pod with a vacume gauage
I also have a chevy perf lt1 hot cam
it just feels like it needs spark plugs bad
maybe I have a bad plug
im gonna go do a vacuum/boost leak test first
but I wanted to know that if I adjuted my valves to tight would they miss and feel like no power
it also seems to be ideling kinda high and my vaucume gauge was -12 600rpm before and now its 800 -20
I cant seem to get to idel down/
Old Aug 27, 2018 | 03:58 PM
bensbaby's Avatar
Engine: 383 built
If I pull the plugs and do a compression test I should have 210 10.5-1 right in all them
what if they are low from the valves somehow being to tight keeping a valve or to open
ideling the car runs perfely
it starts so fast turn key fast
and I have a new walbro fuel pump im gonna put in to
I was just trying to see if I could get it broken in to 1000kms
I have 10km
Old Aug 27, 2018 | 03:59 PM
bensbaby's Avatar
Engine: 383 built
I use 91 I would have to drive 1 hour each way to get 94
Old Aug 27, 2018 | 04:28 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Octane boost from the autoparts store I think you just have detonation.
Old Aug 27, 2018 | 06:55 PM
bensbaby's Avatar
Engine: 383 built
ok I took out my 8 plugs one had a cracked all the way around porcin wiggly loose
I would have never put it on knowing that it was broken
do you all think that that could be it
the spark arcs out when you start trying to go
im gonna try to order them
but im sol for tonight
but I got the front 4 compression test closes to the rad
firewall
---- ----- I cant get to these without taking my fing header off which I have to do tomm
205 205
205 205
rad
and I wll try the octane booster
does anyone know a good one that actually works.
Old Aug 27, 2018 | 06:56 PM
bensbaby's Avatar
Engine: 383 built
my timing is still 7 to 8 ish not 6
it should be 6
that would make it knock less if it was
Old Aug 28, 2018 | 07:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
New plug would help some
but biggest thing is this
“and I had the chip burner guy burn me a chip”
you need to invest in your own tuning equipment
Old Aug 28, 2018 | 10:36 AM
bensbaby's Avatar
Engine: 383 built
I will let you know how it goes
I do have a wideband
Old Aug 28, 2018 | 11:16 AM
Abubaca's Avatar
I'm with Orr. I think it's in the tune. ....mail order is hit or miss. More miss. ....at the very least you'd need the software to at LEAST datalog and get back to the tuner so he can make adjustments.
Old Aug 28, 2018 | 05:29 PM
bensbaby's Avatar
Engine: 383 built
this person I used did it perfectly the first time
and as far as im concerened he did a good job now
the spark plug prorclin was broken all the way around causing a short on the plug
I replaced it took it for a ride and no more missing at allllll
and I felt the power and 1/4 throttle
2000 to 3000
I havnt gone past it but I may tonight just go again
I have a mega header to head leak and when I drive it now for the last couple weeks I get baked
I got some 2007 remflex gaskets and once it cools off tonight im gonna go out again and maybe do I side tonight
its so hot and humid here today I want to puke out
bensbaby's Avatar
Engine: 383 built
scott Hansen.net is the guy I used
for a chip burner
Old Aug 29, 2018 | 05:24 AM
auto_god's Avatar
Car: 1991 Firebird Formula
I'm curious if the spark plugs are the appropriate length/style etc for the aluminum heads you acquired. Some more detail on those may help.
Old Aug 30, 2018 | 05:26 PM
bensbaby's Avatar
Engine: 383 built
i had them custom built from dw performance last year
hes the one who told me what plugs to use
and my cars not missing anymore
its gonna be a wheelie machine
runs like brand new
mad power
6250rpm redline
the spark plug was cracked and arcing out
Old Aug 30, 2018 | 05:55 PM
*** 383 found under hood after brief search ***
Sorry, I just had to
Old Aug 31, 2018 | 06:34 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
use the wideband to make sure its running good
DanielRicany
Feb 19, 2018 07:33 AM
1991z28L98
Feb 10, 2016 02:37 AM
Malicious3rdgen
Oct 28, 2013 01:43 AM
NastyL98_T/A
May 6, 2003 07:52 AM
Timbo89GTA
Jul 20, 2002 11:16 AM
