3.1 Fuel Injector testing/replacement - clarification and advice please
Old Aug 30, 2018 | 09:27 PM
damage31's Avatar
1991 with a 3.1L V6.
OEM injectors with 145,000 on them
Symptoms: Stalled on me taking a right turn the other day, and has recently been acting up slightly for a few seconds when started - noticed a fuel odor and a puff of smoke from exhaust like it was flooded, and also noticed a temporary high idle for a few seconds. Would seem that maybe fuel is leaking down into cylinder(s)
Its not clear to me how to test the injector resistance - must it be done at the individual fuel injector directly under the intake?
Or can it be done at a 6 pin plug that I see located under the throttle body near the coolant temp sensor and thermostat housing?
The 6 pin plug I speak of seems to have 2 coolant temp sensor wires, and then 4 more that are pink/blue and green and one other color I don't recall at the moment but at any rate seemed to match the same exact colors I saw on the fuel injectors.
It appears to me that the 3 drivers side injectors had one set of 2 colors, then the passenger side 3 injectors had another set of two colors.
It seems to me that all 3 injectors on the drivers side all share the same color wires, then same scenario but 2 different colors on the passenger side
So I guess that would account for and give 6 total wires in the plug if I'm not missing something
When I pulled the 6 pin connector, I was getting 4.1ohms across 2 sets of the 6 pins which i assume would be the fuel injectors, and 475 ohms across 2 of the pins which would seem to be the temp sensor.
Engine was hot when checked.
Is this an accurate way of checking the resistance of the fuel injectors? or do you have to pull the top of the intake and release the wires and measure directly on the individual injector?
What other parts (like gaskets) will I need other than what I see here: southbayfuelinjectors ?
Anything else I should replace while I'm in there doing injectors? I think the fuel pressure regulator is in there as well? Does it make sense to do that while I'm in there?
Old Aug 30, 2018 | 11:45 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 3.1 Fuel Injector testing/replacement - clarification and advice please
You're not the first with this kind of problem.
https://www.thirdgen.org/forums/tech...-out-soon.html
Old Aug 31, 2018 | 10:18 AM
GeneralDisorder's Avatar
Check your coolant temp sensor.
SB406
Dec 29, 2004 02:49 PM
388iroc
Southern California Area
May 1, 2002 07:42 PM
Blue502
Pacific Northwest Region
16
Aug 24, 2001 06:37 PM
88GTAChuck
Apr 16, 2001 08:15 PM
