MAF sensor replaced now relays bad?
Old Sep 3, 2018 | 08:20 PM
Nbucz's Avatar
i had the MAF sensor go bad and leaned it out badly. Threw a code 33 and heated the exhaust manifolds to cherry hot. Started the valve cover gaskets in fire!
replade gaskets, thermostat, and MAF sensor. Ran great for a week and started throwing a code 36! also water pump started leaking behind the pulley. Seal failed. Installed a new pump today and still throwing a 36 code. Cannot seem to locate the relays at any parts stores.
Any idea where i might get them??
Old Sep 3, 2018 | 09:11 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: MAF sensor replaced now relays bad?
I dont know whether you need the flat relay or the round one but they are both available on Rock Auto, the AC one is flat and the MAF shows round
https://www.rockauto.com/en/catalog/...sor+relay,3584
Old Sep 4, 2018 | 01:44 AM
Nbucz's Avatar
I need the flat ones but Rick auto only shows one. I want both and they have different numbers. Other posts say they need to be different so where else can I look?
darren8642
Mar 26, 2015 12:42 PM
gta_knight
Sep 12, 2012 08:33 AM
85CheroCamaro
Oct 6, 2009 08:36 PM
Bobby_80s
May 10, 2007 09:55 PM
