305 tbi to 350 tpi help
Old Sep 20, 2018 | 09:35 AM
91formulagtx's Avatar
Car: 1991 Firebird GTX
Transmission: T5 manual
Axle/Gears: 308
The 350 is coming out of a 89 gta 350 with a certificate of destruction that was an automatic car but my 91 is a 305 with a 5 speed manual, I was told I wouldn’t be able to get the 350 tpi to run with the manual car? Anyone know anything about this?
Old Sep 20, 2018 | 11:36 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 tbi to 350 tpi help
the car will run with a manual transmission . However you will benefit form a custom tune.
Is the 91 tbi or tpi ? If it’s tbi I would add the injector pigtail and repin the ecm to a 1227730 ecm.
If its tpi already just get your memcal reprogrammed. Here is a thread on the 746 to 730 ecm.
https://www.thirdgen.org/forums/tpi/...d-density.html
Old Sep 20, 2018 | 11:37 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Sure it will. You will have to get a custom chip burned since there was no 5spd 350 cars but it will work. I'm soon to be swapping an L98 engine into my L03 car but am going with an upgraded TBI setup instead of using the TPI.
Old Sep 20, 2018 | 11:44 AM
Axle/Gears: 308
it’s tbi, any chance you could email me the specifics please?
Old Sep 20, 2018 | 11:47 AM
Engine: Lb9
Transmission: M20
the repinning from tbi to tpi is all on the linked thread.
Old Sep 20, 2018 | 11:49 AM
Axle/Gears: 308
Ok man thank you so much!
Old Sep 20, 2018 | 11:51 AM
Axle/Gears: 308
would I use the ecm in my 91 for the 305 tbi or the ecm from the 350 tpi
Old Sep 20, 2018 | 11:55 AM
Engine: Lb9
Transmission: M20
You could also find a harness from a 90-92 tpi speed density by posting a ad in the classifieds section.
If your not confortable repinning the ecm connector. Here are the connectors needed. If you need a ecm and or chip if you do decide to go speed density send me a pm for reprogramming and possibly a ecm if I have one at the time. I do have one right now.
https://www.ebay.com/itm/90-92-Camar...QAAMXQgb1RPrM4
Tpi maf can be done with the harness you have you just need to double check the firewall connectors pinout. This connector is called c100.
Old Sep 20, 2018 | 11:56 AM
Engine: Lb9
Transmission: M20
You would use a 1227730 ecm from a 90/92 tpi.
Old Sep 20, 2018 | 11:59 AM
Engine: Lb9
Transmission: M20
C100 pinout here so you can see if they are the same or different.
http://www.austinthirdgen.org/?pid=19
slowboy43
Aug 17, 2009 11:39 PM
oracle646
Jul 14, 2008 06:05 PM
danwaite
Sep 2, 2004 02:28 PM
