89 Camaro park/tail lights stay on when fuse is in. (Help)
Tech / General EngineIs your car making a strange sound or won't start? Thinking of adding power with a new combination? Need other technical information or engine specific advice? Don't see another board for your problem? Post it here!
My 89 camaro z28 park/tail lights stay on when fuse is in fuse box. I replaced headlight switch but still same issue. Any help would be great!
Power from tail fuse went to this brown wire i circled. Is that correct?
Re: 89 Camaro park/tail lights stay on when fuse is in. (Help)
Yup, that'll be the taillight wire.
Are they turned off now with the sw unplugged? Aftermarket alarm in the car?
according to my schematic that I have it says that slot is unused. There was a slot with no wire toward the back of switch so I tried running the tail power from fuse box to the rear and now it works.
Probably because one of the purposes of the door chime is to remind you to turn off the lights before you get out of the car; but since the aftermarket alarm you need to find and remove is keeping the lights on, ... the door chime is always on too.
Rewiring a car to "fix" a problem is hardly ever A Good Idea. MUCH BETTER to find the actual problem and fix that instead.
