What brand of fuel sending unit?
Car: 1986 IROC Z
Looking to replace my fuel sending unit this winter as my gauge only goes to 1/4 when full.
What brand or vendor do you guys recommend? Is AC Delco still available out there? If so, where?
Re: What brand of fuel sending unit?
I think I just used the Dorman to match my Dorman tank. Both fit fine and most (if not all) other brands are probably just rebranded Dorman anyway. Get an AEM 340 LPH pump and a fuel pump wiring kit while you are at it. No sense on going that far in without ensuring that you have plenty of fuel for whatever engine the future may bring.
Contrary to popular belief - AC-Delco is not owned by GM at this point and feels free to source their parts from many sources. My recently purchased AC-Delco fuel cap is clearly made by Motorad - hence the large M on it.
GD
GD
Car: 1986 IROC Z
GD
GD
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Fortunately a sending unit is really pretty easy to fix if you can gently pull it apart. There is a good article with pictures on one of the Corvette forums. Next time I'm at a bone yard I'll pull one to try and "adjust" it.
Axle/Gears: 10 Bolt 2.73 Open
One of these two valves came in a nice , fancy , pricey "AC Delco" box from a GM dealer , and the other came from the auto parts store in a plain cardboard colored box for a much cheaper price .
Can you , DynoDave43 , who appear to be claiming there is some supposed superiority of "AC Delco" parts , identify which valve is which ? (Hint , they are IDENTICAL , right down to the same "Made in Mexico" sticker on both , but with different date of manufacture codes) .
"AC Delco" is now nothing more than a scam , a name used to squeak a few more bucks out of the unsuspecting buyer by preying on their sense of brand loyalty !
I defy anyone to look at my two valves and then try to convince me that the "AC Delco" is somehow superior to the "Everco" . Open your eyes , folks , we're getting BONED here with our sense of brand loyalty being used against us .
I checked, and the General Motors Corporation does still hold ACDelco - but the brand is it own entity that sells whatever it wants - need a Alternator for a Honda? No problem ACDelco has you covered. And they do still sell "factory" parts, but because of their relationships with suppliers of all makes and models, when GM (Chevrolet, etc) elects to no longer produce a part or runs out of old stock on a part - ACDelco approaches the same dirty Chinese factory that makes junk for Dorman, Autozone, etc and rebrands that junk instead. The name is meaningless at that point because you really have no idea what you will get.
GD
GD
GD
GD
Car: 1989 Trans Am
Definitely have to be vigilant now when buying AC Delco stuff. The ADVANTAGE line is pure garbage. I think the only good stuff is the ones listed as GM Original Equipment.
That's correct GD. As I said, it's meant to give GM a brand that can be sold in parts stores to compete with other mass market brands, Like a Denso, Wells, Stant, etc. And yes, they are buying and repackaging parts to meet that goal of having parts for many brands of automobile.
I was claiming no superiority in the quality of parts orangebird. I was pointing out that as a GM band, it gave GM some market access it otherwise would not have, and there's value in that for them. Also, in branded service centers (AC Delco, Pep Boys, Napa, Firestone, etc.) that I know the AC Delco centers have some ties to GM from a tech support point of view. That doesn't mean the others are helpless, just that there is some GM support behind the AC Delco brand for shops flying their flag.
Now , as to general marketing perception , it was always advertised that "factory" parts were supposed to be mechanically superior to cheaper aftermarket components , in fact GM's "Mr. Goodwrench" campaign made much ado about the superiority of "factory direct" parts & repairs . To find the exact same part in an AC Delco box and an Everco box now means that it's crazy to pay almost 2X the price for fancy packaging (and the not needed tech support to install the same made in Mexico valve no matter which box it came in) .
Donald Croes
Jul 3, 2016 12:19 PM
Z28GARAGE
Mar 19, 2011 05:49 PM
mikesz1984
Alternative Port EFI Intakes
Sep 21, 2009 01:34 PM
Jeremysyty
Aug 24, 2008 03:07 PM
