Help finding possible vacuum leak
Old Dec 17, 2018 | 10:19 AM
shaynecastongua's Avatar
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
I know there are a million vacuum leak threads, sorry for posting another. I have been hunting down the cause of my high idle (was around 2500). Yesterday I re-torqued the carb bolts which brought it down to 1700 (the gasket is new, I figured it was just settling in. Re-torquing the intake bolts yielded no help. Using carb cleaner and propane didn't give me any response from the engine. I tried feeding the propane directly down the carb throat, and the engine once again did not respond. If I can't get a noticeable RPM change with propane or carb cleaner, how else can I find this leak? I also re-checked the timing on the engine as well, 8 degrees advanced at TDC. I'm really hoping the leak isn't internal to the manifold, is there any way to differentiate whether the leak is inside or outside the manifold? Thank you in advance.
Old Dec 17, 2018 | 10:34 AM
Car: 1985 Trans Am
Engine: Chevy 355
Re: Help finding possible vacuum leak
Additional info: I have adjusted the transition slot, idle speed screw (it's all the way closed), fast idle screw, and the mixture screws are at 1.5 turns from bottomed out.
Old Dec 17, 2018 | 01:28 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
It's getting in there from somewhere. Have you blocked off all the vacuum ports?
Old Dec 17, 2018 | 03:28 PM
Car: 1985 Trans Am
Engine: Chevy 355
I had tried blocking off all the vacuum ports, with no change to performance. I got a hold of a smoke machine, which showed smoke coming from both my valve cover vents, I didn't realize you should not run both breathers and PCV, there's my vacuum leak!
Old Dec 17, 2018 | 06:34 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Yeah i was about to say 2500rpm at idle isnt a vacuum "leak"... thats pure unadulterated flow!
Old Dec 18, 2018 | 07:26 PM
Sounds like maybe the wrong gasket.
Torquing carb bolts is rarely a good idea.
Old Dec 19, 2018 | 02:35 PM
Car: 1985 Trans Am
Engine: Chevy 355
I capped off one of my breathers and got it to idle around 1100, I'm going to retime it and keep adjusting the carb, but for now I can live with 1100. I'll update the thread if I run into any more problems, thanks guys!
jstratouly
Sep 12, 2014 09:21 PM
ATCharming
Jun 29, 2009 03:33 PM
Bobby_80s
May 23, 2008 12:54 PM
bstieboydp
Jun 15, 2005 04:45 PM
gunnman54
May 19, 2001 12:27 AM
