1984 firebird problems rough idle please help
Old Jan 6, 2019 | 07:41 PM
jesus9814's Avatar
Hey guys been trying to get this 1984 firebird with 5.0 engine on the road, I bought a rebuilt Quadra jet and car was running ok but when temperature drop started to run very rough and dies any ideas what could be wrong I have attached a link video of car running
Old Jan 7, 2019 | 09:58 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: 1984 firebird problems rough idle please help
If it's only affected when it's really cold out and fine when the outside temp is warm, the first thing I'd check would be the choke pull-off on the carb. They have a tendency to leak, which makes the car run rough until it's warmed up.
Here's more info on the choke pull-off: http://www.carburetor-blog.com/how-t...hoke-pull-off/
Very easy to test, just remove vacuum line from it, push the plunger all the way down, then while holding it down, plug the vacuum line inlet with the tip of the your finger, then let go of the plunger. The plunger should only move a fraction of an inch when letting go of it while blocking the vacuum port with your finger. If the plunger goes all the way back to its resting position, you'll know the choke pull-off is bad.
Old Jan 7, 2019 | 11:49 AM
jesus9814's Avatar
Thanks for the info will try it later today and update, it’s not super cold I’m in California is only 35-55 trough out the day but after it sat for a week and the temperature drop it started running rough
Old Jan 7, 2019 | 06:24 PM
jesus9814's Avatar
navy02ws6
I tried the method to check the pull off, it only moved very little but it starting throwing white smoke like a burning smell it got very hot under the passenger seat not sure why that happen is first time I have experience that it seems like under the car in the passanger side was getting very hot for some odd reason, it also seem to run better with filter assembly off
Old Jan 8, 2019 | 10:15 AM
navy02ws6's Avatar
Sounds like the choke pulloff is good. The catalytic converter is right under the passenger's floorboard, and can get ridiculously hot if your air/fuel ratio is off, which it sounds like it is. Was this carburetor that you bought professionally adjusted and set up after the install? Or did you just take it out of the box and bolt it on?
Old Jan 8, 2019 | 10:45 AM
jesus9814's Avatar
A mechanic installed it and adjusted it, but it was still running a little rough and wouldn’t pass smog after he did, he also change oxygen sensor and adjust timing but car never run smoothly was still a little shaky but it started getting bad recently when weather got colder, so it might be that the carburetor needs adjustment? It stop getting hot after I put all the air filter housing back
Old Jan 8, 2019 | 10:58 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
I don't know how good your mechanic is, but most modern day mechanic's i see, don't know a thing about carburetors. You may need to find an old guy sitting in a rocking chair on a front porch that used to work on Carbs.
Old Jan 13, 2019 | 12:17 AM
jesus9814's Avatar
That’s what I was thinking, maybe mechanic did not adjust it correctly, car used to run better with old carb and motor was not shaking, now it developed new symptom car hesitates and make puff noise when accelerating
Old Jan 13, 2019 | 10:25 AM
red rock's Avatar
Car: 1987 iroc
Smell the exhaust, if it's running rich, it will almost burn your eyes.
gunner6262
Aug 3, 2008 08:38 AM
90-irocdx3
May 13, 2006 07:45 AM
PACMAN007
Jul 3, 2005 07:04 PM
BigChevy342
Jul 22, 2001 11:06 PM
BigChevy342
