WHAT IS THE CORRECT TYPE POWER STEERING FLUID TO USE?
Old Jan 28, 2019 | 09:27 PM
JimRockford's Avatar
Hi,I have to replace the power steering pump on my 90 Camaro and was wondering what the correct fluid is to use in the power steering system. Can you just use any power steering fluid,like prestone,stp,or Autozone brand? Or does it use atf fluid? They don’t make dexron 3 anymore,but sell a Castrol dex/merc atf fluid. Is it better to use an actual power steering fluid over atf?
Old Jan 28, 2019 | 10:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: WHAT IS THE CORRECT TYPE POWER STEERING FLUID TO USE?
Dexron II was phased out decades ago. Dexron III is also obsolete. You can use any newer ATF or just put in power steering fluid or any other lightweight hydraulic oil. They all do the same thing. ATF just happens to use a red dye.
Old Jan 28, 2019 | 11:58 PM
GeneralDisorder's Avatar
Amsoil OE ATF works excellent for me on all GM PS systems.
GD
Old Jan 29, 2019 | 05:00 AM
Vader's Avatar
Any hydraulic oil meeting MIL-H-5606G specifications is acceptable. That includes mineral and synthetic oils.
Old Jan 29, 2019 | 08:44 AM
Ok,thanks guys. So pretty much any power steering fluid works or I can use the castrol dex/merc without any harm? The friction modifiers in transmission fluid won’t harm anything?
Old Jan 29, 2019 | 08:48 AM
I just went in the castrol website for the dex/merc specs and info and it sounds like it’s dex 3. It also recommends if for use in older gm power steering systems.“Castrol Transmax™ DEX/MERC Multi-Vehicle Transmission Fluid is for use in transmissions and power steering of older Ford and General Motors vehicles and any other vehicle where the specifications for this product are recommended. “
evilemokid94
Mar 3, 2013 01:15 AM
Stevolwevol
Aug 16, 2010 01:27 AM
david auster
Nov 20, 2003 01:28 PM
pauls
Feb 1, 2002 08:38 PM
SIMON HOLTBY
Nov 28, 2000 09:52 PM
