Positive terminal
Old Jan 31, 2019 | 01:35 AM
Panda5087's Avatar
Car: 1986 iroc-z/1985 trans am
Positive terminal
I recently purchased a 86 iroc-z. The previous owner decided for some odd reason to completely cut the battery cables out does anyone have a diagram or picture of how to or were the positive and negative battery terminals connect to, I know theres the starter and another positive wire to the fuse panel just trying to locate placement of wires
Old Feb 3, 2019 | 10:34 AM
Re: Positive terminal
Main positive cable goes from the batt to the starter solenoid. Some variants also had a pigtail to the alternator (charge wire), and some a pigtail to the ECM.
Negative is from batt to the "pistol" or "Indiana" bracket below the alt, with a pigtail to the core support.
Old Feb 3, 2019 | 11:05 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Not sure how much is similar between '86 Chevy and '88 Pontiac, but here's a picture of my car with it's original cables, when I pulled the battery to clean up the tray.
You'll notice it uses a smaller gauge wire off of the positive terminal to feed an accessory block. Don't know if you have that or not, but if you do, you'll want to get power to it.
https://www.thirdgen.org/forums/memb...ml#post6029362
dustierdog
Aug 25, 2011 11:56 AM
bigchief
Aug 28, 2006 12:30 AM
Viking
Jan 2, 2003 01:25 PM
