Distributor
Old Feb 9, 2019 | 11:45 AM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
Distributor
Found this when I pulled the intake for a gasket leak.
27k miles
Is there a fix or do I get a new one
Old Feb 9, 2019 | 12:22 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Distributor
Just clean it up and regoop the ign module. Don't use carb cleaner near the pickupcoil, it'll turn it to a gooey mess.
Old Feb 9, 2019 | 01:58 PM
BigBlock73's Avatar
Engine: 5.7
Re: Distributor
Should I disassemble it?
How should I remove the rust?
What goop should I use?
Old Feb 9, 2019 | 02:36 PM
GeneralDisorder's Avatar
Re: Distributor
Brush off the loose stuff and apply new thermal grease to the module. Otherwise just leave it alone. The bit that is rusty is the reluctor and the rust is not going to affect it's operation. They all look like that due to moisture and ozone that's created inside the cap.
GD
Old Feb 9, 2019 | 06:53 PM
BigBlock73's Avatar
Engine: 5.7
Re: Distributor
Good news.
The least expensive option.
Old Feb 10, 2019 | 06:10 AM
BigBlock73's Avatar
Engine: 5.7
Re: Distributor
Is this a good choice for thermal paste?
Thanks for your time.
https://smile.amazon.com/dp/B0087X72...v_ov_lig_dp_it
Old Feb 10, 2019 | 08:19 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Distributor
That's from moisture. Use a small brush to remove the loose bits. If that is still a factory pickup coil on a factory distributor it should use a snap ring to hold it in place. If its aftermarket it probably uses a clip that must be destroyed to remove it. You could remove it if you wanted to clean a little better but it sounds as if it isn't giving you problems so I wouldn't remove it. Make sure the screens on the bottom of the distributor base plate are clean and not blocked. Make sure you don't also have corrosion at the Ignition Control Module and Pickup coil connector. You can put a thin bead of dielectric grease on the bottom of the cap as a seal to help keep moisture out that way. The other way to move air inside the cap would be to use GM # 10477219 rotor. It has fins on the bottom designed to move air over the Ignition Control Module and help remove moisture through the screens. Buy whatever magic goop you want, as long as you use something it's not going to make a difference.
Old Feb 10, 2019 | 12:40 PM
Re: Distributor
Yes that's a good choice.
Old Feb 10, 2019 | 06:19 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: Distributor
mine looked a lot like this, had endless connectivity issues and the pickup coil was stuffed in the end. They really arent that expensive considering how much work they do and how long they last.
Old Feb 10, 2019 | 07:00 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Distributor
If you are worried about the functionality of the Pickup coil then just test it. Pull the 2 prong connector from the pickup to the module. Stick a paperclip in each of it's female sockets and hook your multi-meter up to each paperclip. Set the multi-meter on AC voltage. Remove the rotor and hook up a 1/2" drill's chuck to where the rotor was. slowly begin to turn the drill and observe the multi-meter. The voltage should fluctuate evenly up and down because it's making a sinusoidal AC wave. Turn the drill faster and it should alternate faster. Oscilloscope is the best way to do this but multi-meter will work just as well.
AFRO IROC Z
Dec 16, 2012 04:56 AM
chickenhawk
Aug 8, 2006 12:04 PM
spedrace35
Nov 22, 2005 10:08 PM
