Ls7 lifters max lift?
Old Feb 20, 2019 | 05:46 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So I noticed that the ls7 lifters are not clearanced as much as even the stock lifters... Are you guys running these on higher lift more aggressive lobes?
Old Feb 20, 2019 | 07:29 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Ls7 lifters max lift?
I think it's maybe the only lifter you can buy anymore. It's the service part for all the LS engines.
Old Feb 20, 2019 | 09:09 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
From GM perhaps, I'm just surprised that they are not machined for high lift. I wonder if I might have a prkbpro...
Old Feb 21, 2019 | 12:43 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
What do you call high lift?
I think my stroker engine has 0.630 lift with a 1.7 rocker.
Old Feb 21, 2019 | 06:24 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Notnot sure, they may very well just be fine I just find it odd that the factory lifters are clearanced on the sides so the lifter body can never touch the cam. When you Google aftermarket high lift lifters the bodies are even more clearance, yet these LS7 lifters are not at all.
it may have nothing to do with the actual lift but rather how steep the ramp is.
I've never actually seen a hydraulic roller lifter that wasn't clearanced, so when I took these out of the box last night to install them I was kind of like what?! So I stopped.
-- Joe
Old Feb 21, 2019 | 06:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I ran a .383 lobe on a 1.6 rocker just fine on my gen 1 hyd roller block.
comp magnum high lift lobe. Not stupid aggressive but aint mild
guys run xfi .360-.370’s lobes on them just fine. No clearance issues. Some ls lobes even more aggressive but bigger cam cores
Old Feb 21, 2019 | 07:04 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Nevermind this. I didn't realize this was not an LS engine.
Old Feb 21, 2019 | 12:06 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
don't know that it matters much, unless the base circle is dramatically different.
-- Joe
Old Feb 21, 2019 | 12:07 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Guess it will be fine then. Just find it rather odd.
-- Joe
Old Feb 21, 2019 | 12:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
What’s the difference in running Delphi’s vs ls lifters.
are the ls lifters better in some way ?
Old Feb 21, 2019 | 12:11 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I think those are LS7 lifters.
-- Joe
Old Feb 21, 2019 | 12:14 PM
Engine: Lb9
Transmission: M20
Can they be used in a sbc ?
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I hear the delphis are not the same and not as good hence why they cost much less
lol 10 yrs ago ls7’s were 130$ now they are 215$
Old Feb 21, 2019 | 12:16 PM
Engine: Lb9
Transmission: M20
Ouch , but I guess you get what you pay for.
Old Feb 21, 2019 | 12:33 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hmmm. I'm seeing oem GM ls7 for $109..
Who knows. As long as they can handle the spring pressure..
-- Joe
Old Feb 21, 2019 | 12:36 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
-- Joe
from where? I would question that source
Old Feb 21, 2019 | 01:02 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Just type ls7 lifters in google and click shopping.
I agree some might be BS, but I trust vendors like speedway motors.
https://www.speedwaymotors.com/LS7-R...SABEgILsfD_BwE
-- Joe
Old Feb 21, 2019 | 01:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats for 8 but still good price if really non delphi gm parts
BTR sells them for 214
Old Feb 21, 2019 | 01:14 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I think I paid like $125 or something for my set. Said OEM GM and have blue paint on them. Unboxed though.
Anyway. I guess I'll put them in.
Right now I'm trying to find a cam plug locally for the back of the block. wasn't one in my box of freeze plugs. ugh.
-- Joe
Old Feb 22, 2019 | 02:04 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Which sbc? '87 and later roller blocks - yes. Earlier blocks - no!
Old Feb 22, 2019 | 08:16 PM
Engine: Lb9
Transmission: M20
On a roller block do they still use 7.2 push rods ?
Old Feb 22, 2019 | 08:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Used to be said the pushrod cup sat lower by near .060 when they first came out. Not sure of that now or then, never measured to be sure. But on aftermarket cams i ran them with on aftermarket heads the pushrods were longer than 7.20
Old Feb 27, 2019 | 11:32 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
3 years ago they were $130 a set. I always pay employee price being a dealership employee with a GM sister store. Dealer cost plus 10% pricing.
I have them in my Vortec 350. Comp Magnum high lift lobes with 1.7 rockers at .578" lift. 155# on the seat and 350# open double springs. Shift at 6,200 with a 6,500 rpm fuel kill. Has seen multiple dyno runs to 6,500. Also saw numerous 6,500 rpm fuel shut-offs dialing in the 4L85E shift points.
Old Feb 27, 2019 | 11:36 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My geometry was perfect with aftermarket assault racing heads that were milled .020", have .100" longer valves, comp cam on magnum lobes and and 1.7 rockers with 7.2" comp magnum pushrods.. Maybe I just got lucky. Thats why you ALWAYS check your setup. An adjustable setup pushrod is a very valuable addition to the tool box.
DAVECS1
Nov 30, 2011 10:52 PM
vetteoz
Jun 2, 2008 09:27 PM
Iroc You
May 31, 2008 11:15 AM
ZONES89RS
Apr 14, 2008 10:06 PM
Iroc You
Apr 8, 2008 08:46 PM
