Engine fire cause?
Old Mar 1, 2019 | 12:28 AM
xbazzarex's Avatar
Car: 1985 T/a, 1988 Formula
Engine: LB9 and LO3
Transmission: 700R4 and 700R4
Axle/Gears: 9 bolt 3.27, unknown
Engine fire cause?
long story with my 88 firebird, car stopped running back in December. I did a mess of work in the engine bay, replacing worn out things and tracking down the issue. The issue ended up being a jumped timing chain, and later the ICM. I also replaced the spark plugs and wires, alternator, upper and lower rad hoses, pcv valve and grommet, air filter, and a few other things. The timing chain replacement was cake compared to the spark plug change. Anyway the car started after the timing chain but ended up dying again, I tracked that down to the ICM having gone bad. car starts and runs fine after clearing up the spark plugs. I run the car down to the gas station to get air for the tires, and i notice it seems a bit off( im thinking timing needs to be adjusted at this point). Heading back home i notice ive lost a lot of power, i pull in to my driveway which is going uphill and work the car up when i notice that smoke has started coming out of the passenger side of the hood. I stop, place it in park, ebrake on, turn the car off and pop the hood, BAM fire on the passenger side right where all the sparkplug wires are. Does it sound plausible that the plastic clip that holds the wires may have come loose or broke and let the wire make contact with the exhaust manifold, causing it to melt and catch fire? 2 plugs were melted down to the wire, 1 was only slightly melted, and 1 was melted in half. i have to get someone to give me a hand pushing it back in the garage, because of the awful spark plug placement on these cars i cant get a fresh set of wires back on it to try and make it run. so im still kinda just looking at the car from the top and trying to see what was all damaged and what was the cause.
Old Mar 1, 2019 | 01:25 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Re: Engine fire cause?
Here is my experience.
I've had two 1991 Camaros: a 3.1 V6 and the 5.7 Z28 I have now. I've had engine fires in BOTH.
The V6 caught fire while I was driving it and when I opened the hood, there was a blowtorch blasting straight up from around the rear of the intake on the passenger side. I had an MSD coil on a custom bracket mounted to the intake right in that area, so I thought perhaps it had overheated and cooked off?? Anyway, when I lowered the hood down to try and partially quench the fire while I tried to find an extinguisher, the hood latched and the release burned through before the fire department arrived and it burned to the ground.
I bought the Z28 to replace it, figuring I'd step up to a V8. I subsequently have had THREE fires in it, and in each case, I got the fire out(never go without an extinguisher EVER again) and saved the car! I could not for the life of me(actually, that's not a bad way of putting it!) figure out what was going on until one day, while I had the ignition on but no start, I spotted the Schraeder valve leaking on the fuel rail! The port where you attach a gauge to check fuel pressure. So now I had a fuel source. And then, in checking each of the plug wires, I found one that was cracked and arching. Boyah! Fuel source AND ignition equals FIRE. I immediately replaced the valve- get the RIGHT one, not one from a bicycle shop!- and put the proper cap on the port- hell, I even JB welded it on. That sucker is NOT leaking again! So, try turning the ignition key to ON, and check that port for leaking fuel...!
Old Mar 1, 2019 | 01:38 AM
TAbracadabra's Avatar
Car: 1986 IROC-Z
Axle/Gears: Presently Open w/3.23 Ratio
It might be helpful to see what you are seeing. Could you provide us some pictures?
Old Mar 1, 2019 | 11:57 AM
GeneralDisorder's Avatar
Probably some kind of fuel leak. TPI? There's a lot of places for leaks on them.
GD
Old Mar 1, 2019 | 08:15 PM
xbazzarex's Avatar
Engine: LB9 and LO3
TBI engine, it was a small fire and i havent had a chance to clean the bay out, its still covered in extinguisher dust. The fire was small and looks to have only damaged the spark plug wires and the one sensor that sits up on the overhang from the cowl. ill double check the fuel system once i get it in my garage again. I have the tool for replacing the cores in the schraeder valves.
Old Mar 1, 2019 | 09:37 PM
Clean off the extinguisher powder - it destroys paint and promotes rust. And in the future buy a Halon style unit.
GD
Old Mar 4, 2019 | 04:46 PM
xbazzarex's Avatar
Engine: LB9 and LO3
This seems to be the extent of the damage, nothing else seems to be burnt. Excuse the extinguisher dust, shop vac died part way through.
Old Mar 4, 2019 | 04:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Fuel leaking from the hardlines at the Throttlebody?
https://www.tpiparts.net/inc/sdetail/2343
babybear82lilj
Feb 5, 2008 05:12 PM
ULTM8Z
Mar 28, 2006 03:47 PM
Lee7
Sep 27, 2003 09:46 AM
breathment
Oct 16, 2001 11:40 PM
SiDeWaYS Z28
Dec 28, 2000 05:39 AM
