Fuel Sending Unit Feed Line Fitting Size
Old Mar 7, 2019 | 08:23 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Does anyone know the fitting size for the sender's feed line? I'm trying to find an AN adapter to run braided hose to a C5 filter for my LS swap and can't seem to find anywhere the size of the fitting for the feed.
Old Mar 9, 2019 | 12:56 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Fuel Sending Unit Feed Line Fitting Size
The feed line (the hard line portion of it) is 3/8" and I just cut it and flared on a -6AN fitting. No leaks ever. The return line is a 5/16 and you can use a 5/16 compression fitting to -6AN
madigidy
Dec 17, 2011 01:45 AM
RaverRacerX
Apr 25, 2011 02:08 AM
Fastbird
Dec 23, 2008 11:56 AM
Confuzed1
Apr 20, 2004 05:52 PM
