A.I.R. Injection brace bolt hole leak - do they leak from factory?
Old Mar 7, 2019 | 09:39 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Question about the A.I.R. Injection brace bolt hole leak. The bolt hole used to bolt the brace/bracket which the air pump and a/c compressor are attached to. Near the old fuel pump bolt cover. It appears I have the leak, but everything is stock. Are these known to leak, even with a bolt in them? It had never been apart in the past, so everything is bone stock from the factory.
(Stole this picture from another thread - apparently this is known as the Sofakingdom bolt hole leak)
Old Mar 7, 2019 | 09:46 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: A.I.R. Injection brace bolt hole leak - do they leak from factory?
They sure can. Remove bolt (or stud) clean threads with a spray cleaner of choice, put sealant on threads and put it back in. I use Teflon paste for pipe threads.
Old Mar 7, 2019 | 09:50 AM
LiquidBlue's Avatar
Transmission: MD8
Thanks a bunch, all evidence pointed to it, but couldn't seem to locate another source..... so was scratching my head as to how it could leak so much
Old Mar 7, 2019 | 02:53 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I did not know about this one. Lesson learned (if I can still remember it when I need it).
And Wow! Sofa got a bolt hole leak named for him? Sweet!
Old Mar 7, 2019 | 03:28 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Curious does that bolt open into a oil or water gallery? That is what was leaking?
Old Mar 7, 2019 | 03:41 PM
LiquidBlue's Avatar
Transmission: MD8
not exactly sure what it is, but its oil. i have read it is a remnant of the days of mechanical fuel pumps. the sbc block hadn't changed, and the fuel pump opening is just capped off. what I do know for sure, is with the bolt out, I can run a piece of wire into a hole, guessing an oil galley.
Old Mar 7, 2019 | 04:46 PM
TTOP350's Avatar
It's just open to the fuelpump pushrod hole which is open to the inside of the engine. Just crankcase pressures.
When removing a old mechanical fuel pump, you take out that short bolt, put in a longer one, snug it to hold the fuel pump pushrod in place so it doesn't fall out.
Old Mar 7, 2019 | 09:37 PM
NoEmissions84TA's Avatar
Yes, it's a drip lubrication hole to lubricate the FP pushrod.
Old Mar 8, 2019 | 06:58 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
and inadvertently crank down too hard (not much is really required) and snap the push rod, turning the job into an all dayer after a visit to two or three parts store for a new rod which no one seems to carry anymore.
Old Mar 8, 2019 | 08:01 AM
TTOP350's Avatar
Holy crap, If you can even snap it b4 stripping the threads out, my hats off to you!!!
Old Mar 8, 2019 | 03:08 PM
naf's Avatar
naf
it shattered, non-ductile, brittle failure
couldn't have been more than 20 ft-lbs-the threads were tight and i didn't feel the bolt engage the rod
just be careful with the torque on the hold down bolt.
Old Mar 8, 2019 | 06:12 PM
BizJetTech's Avatar
Old Mar 12, 2019 | 02:14 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
def hardens and brittle, back when I had a mech pump I shattered one by dropping it off the hood of my truck onto the driveway
87irocftw
Aug 5, 2011 02:51 PM
camaronewbie
Dec 17, 2009 08:31 PM
CamarosRUS
Carburetors
Dec 28, 2008 08:08 PM
hotrodhed120
Apr 24, 2006 02:22 PM
CamarosRUS
May 26, 2004 07:32 PM
