No spark issue
Old 03-28-2019, 03:33 PM
poizonpyo's Avatar
Car: '89 Firebird
Engine: 5.7L 350 TPI
Transmission: Auto :/
No spark issue
I'm having a crank no start issue that seems to be stemming from a no spark issue. I pulled one of the plugs (it is dirty and looks worn, but car was running fine last fall) and checked it for spark and nothing. Pulled the distributor cap, cleaned all the contacts which weren't all that dirty and checked to make sure it was spinning. Then I connected a plug to the coil wire, and again checked for spark and found nothing. I checked the voltage and the coil had 13.8 going into it. Thinking the ignition coil was bad, I changed that out and still have no spark coming from the coil with a grounded plug. The fuse for the ECM/IGN is fine. Could all of the spark plugs have gone bad over winter at once? Is it perhaps a bad ignition control module? '89 5.7l TPI
Old 03-28-2019, 04:10 PM
GeneralDisorder's Avatar
Re: No spark issue
Probably the module in the distributor.
GD
Old 03-28-2019, 04:14 PM
poizonpyo's Avatar
Car: '89 Firebird
Re: No spark issue
That was gonna be the next thing I replaced. Knew I should have just grabbed the ICM while I was at the store earlier.
breathment
01-23-2020 03:43 PM
jonnyboyskate
12-10-2014 04:44 PM
ptc92rs
10-24-2001 01:14 AM
zedder 1 9 9 0
07-09-2001 11:28 PM
ChevypickupTPI
10-26-2000 10:42 AM
Quick Reply: No spark issue
