AC Delete
Old Mar 30, 2019 | 03:53 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
AC Delete
I'm looking to delete my A/C Compressor and all that stuff associated with A/C pretty quick. I see AC Delete pulley's for like $35 at Autozone but then I see pulley's at reputable websites for like $100+. Should I be cautious as to which pulley I choose? Or I wonder if I can just eliminate the darn thing and get a shorter belt? In which case, is there a tensioner that I need to invest in? Thanks in advance!
Old Mar 30, 2019 | 06:07 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: AC Delete
I think you would need an entire new serpentine system like a March or similar to eliminate the pulley completely.
I used an AC Delco delete pulley. It's only been on for a few days but seems fine. I read some bad reviews of the Dorman unit's alignment.
https://www.ebay.com/itm/ACDelco-10055890-New-Idler-Pulley/192854522009?epid=114919746&hash=item2ce7067899:gfcAAOSwISRad7B1
Old Mar 30, 2019 | 06:34 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: AC Delete
If you want to just pull out the compressor, the best way to go is the GM AC delete pulley and bracket, there are plenty of "real" ones around at wreckers and such, but if you are gonna take the whole system out, you need to get a whole list of parts, and there are a variety of ways to achieve the end result.... If you don't care about AC - and lots of people don't - there are a lot of performance positives to deleting it.
hookin88formula
Aug 15, 2008 09:44 AM
Zepher
Jul 23, 2003 10:18 PM
CamaroEFI
Jun 9, 2003 03:08 PM
Spyder
May 1, 2001 04:03 PM
