l98 Cam sugestions
Old May 9, 2019 | 08:29 PM
Mikegh's Avatar
Car: 1985 Z28
l98 Cam sugestions
I building a l98 out of an 87 vette for my 85 Z28 looking for a mild cam was thinking about l98 super cam. Im using 1.6 roller tip rockers and stock tpi intake,trying to keep stock pushrods and valve train.
Old May 9, 2019 | 09:05 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: l98 Cam sugestions
What engine management system are you using, if you are staying close to stock on everything, check out TPIS Inc, they have a ZZ9 that sounds like exactly what you are looking for... check it out.
Old May 9, 2019 | 09:09 PM
427seven's Avatar
I used this can in a more or less stock TPI that was run by a chipped stock computer, it worked VERY WELL.... Mind you , I had a racers prep on the engine, pay special attention to the porting from the airfoil to the valves and you need headers.... (Dyno Don)
Old May 9, 2019 | 09:25 PM
Mikegh's Avatar
Car: 1985 Z28
Im using stock computer and prom I think that might be too much lift with 1.6 rockers and stock springs, did you have to use different push rods?
Old May 9, 2019 | 09:47 PM
427seven's Avatar
Not different pushrods, if you think it's a bit too much cam, stick with a 1.5's on it, then if you modify the rest of the engine a bit more, add the 1.6's later, the cam will already be in there.
Old May 9, 2019 | 09:48 PM
427seven's Avatar
Phone those guys up or email them, they're very approachable and yo can tell them exactly what you have going on and they will tell you what you need to do....
Old May 9, 2019 | 11:58 PM
kenmaisaano's Avatar
If its a roller engine. I have a brand new in the box Crane Smog legal H roller its a litter hotter than the factory 1989 five speed 305 cam.
Crane #2031 208 214 264 270 112 .438 .452 I paid $450 will take $225 plus shipping . PM me if interested.
LoganKello
Jan 24, 2011 01:12 PM
ALLTEC-Z
May 4, 2007 08:12 PM
86 sports coupe
Aug 27, 2001 12:02 AM
SUPER-SPORT-CHEVY
Jun 27, 2001 01:19 PM
Slow83Z28Camaro
Carburetors
Apr 23, 2001 10:24 PM
