2 spectra mechanical fuel pumps failed un 2 years?
Old May 10, 2019 | 06:26 PM
Camaro-3's Avatar
Hello,
On 2017 spring, I have buy a Camaro with a 305 quadrajet. I replaced the fuel pump in prevention before it Gets old. The New one was a Spectra mechanical fuel pump. On 2018 spring, I took out the car from the garage and after about 100 miles, the engine began to sputters under load intermittently (only when warm-hot). I checked all related things and finally, the fuel pressure was the culprit, it seemed the diaphragm was leaking when the pump dilates when hot. When cold, it was ok. I removed the pump to change it and the pump falls in pieces when removing it (the lever, the pin and the spring had gone off). Replaced it and the car ran like champ another year. At spring of 2019, I took the car from the garage and ran 600 miles without problem, but after that, whennthe engine was warm-hot, the engine began to sputters at idle and the idle was low... The cars began to hesitates on accélération, and the engine stalled suddenly without any possibility of starting it again until it gets cold. But cold, it was fine again. Last week I removed the old spectra pump to change it, and it was in pieces again ! (Lever, pin and spring falls to Ground when removing). I changed it for another pump and it runs ok now... But im wondering whats the real problem? Are spectra pumps crap? Do you think it's because I have a fuel Filter before the pump which Makes restriction and causes the pump to fail? I installed it to prevent crap from fuel tank to go into the pump.
Other ideas of the cause of the failing pumps?
Old May 10, 2019 | 06:44 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 2 spectra mechanical fuel pumps failed un 2 years?
what is the country of origin of those pumps?
Old May 10, 2019 | 06:52 PM
Camaro-3's Avatar
I think the parts are made un Korea and it is assembled in Canada.
Old May 11, 2019 | 11:17 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Replace it with a Carter.
I stopped buying anything made by Spectra years ago when I went through a bunch of their junk. One was a new fuel filter that leaked gas all over my engine bay. I decided the fuel system was no place to skimp on parts because I don't need my car going up in flames from some knockoff junk leaking fuel all over a hot/flammable engine bay.
afremont
Oct 21, 2012 07:32 PM
88camaroscv6
Aftermarket Product Review
Jun 1, 2012 11:16 AM
camaropep
May 13, 2012 08:58 AM
drdrdaddeo
Dec 14, 2010 04:10 PM
ghettocruiser
Nov 23, 2002 01:47 PM
