HELP Please! I need image of 1989 under-hood emission decal!
Tech / General EngineIs your car making a strange sound or won't start? Thinking of adding power with a new combination? Need other technical information or engine specific advice? Don't see another board for your problem? Post it here!
Hi. My 1989 IROC Z Vert 305 TPI AT is missing it's Federal California Emission decal. (I am not sure if it is a Ca. or Federal car. It might be Federal).
The one that reads basically This Vehicle Conforms to California(Federal) Emissions Standards. It also refers to the Ignition timing, lists "Catalyst" etc. I need a good image of the label, so I can print it and apply underhood, where it was originally. I need to SMOG the vehicle and I do not want to try without the label.
Any help appreciated! (I tried several vendors, who seem to have decals from 1968 -92 EXCEPT ONE YEAR, guess which year they don't have)!
The SPID and tin underhood plate, is also missing. FWIW.
Re: HELP Please! I need image of 1989 under-hood emission decal!
Thank you both!!
I found several decals images on google, w/ conflicting ignition timing specs. (8* VS 6* BTDC). Anyone OWN an 89 LB9 305 TPI, who could advise specs, on the decal? Maybe post a photo? The "If Built for Canada" is something I have never encountered, and as a former Service Manager, I have read thousands of Emission Decals.
My FSM and Haynes Manual, refer to decal, don't list timing specs. Thanks.
