Vortec intake gasket options
Old Jun 18, 2019 | 11:37 AM
ironhead88's Avatar
Hi guys
I've been trying to find a good intake manifold gasket for vortec heads that is about .060" thick.
This is for a carb intake BTW
It seems like the thinner ones I see get bad reviews, and the only one that consistently gets good reviews is the Fel - Pro 1255 that's .120" thick.
I've decked my block to yield .040" squish and I'm using some .015" offset dowels as well - but even still, a .120 intake gasket is too thick.
I'm just checking my options for a thinner gasket before I have my intake machined.
Has anyone used a .060" thick Fel-Pro 1206 for a vortec carbed intake, and just relocate the mounting holes to match the vortec intake pattern?
A .060" thick gasket would be the answer if there's one out there that works.
Thanks for sharing
Old Jun 19, 2019 | 12:05 PM
ironhead88's Avatar
Re: Vortec intake gasket options
Old Jun 19, 2019 | 03:09 PM
ironhead88's Avatar
Seriously?
I cant be the only one who's had to deal with this
Bump
Old Jun 20, 2019 | 04:47 PM
InTech's Avatar
Hello,
If the heads are cut and you don't want to cut the intake manifold, BLP has these. Most Vortec intake gaskets are ~.125" thick.
https://blp.com/cart/index.php?main_pag ... ts_id=1052 These are .031" thick
http://blp.com/cart/index.php?main_page ... ts_id=1053 These are .047" thick
https://blp.com/cart/index.php?main_pag ... ts_id=1054 These are .062" thick
https://blp.com/cart/index.php?main_pag ... ts_id=1055 These are .095" thick
http://blp.com/cart/index.php?main_page ... ts_id=1056 These are .125" thick
Old Jun 21, 2019 | 05:29 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
I just used stock replacement ones from Auto Zone. Never had a problem in 5 years. Used RTV instead of the end gaskets.
Old Jun 21, 2019 | 08:37 PM
ironhead88's Avatar
I ended up getting Mahle MS20009
Theyre .060" thick laminated w steel internal
Old Jun 21, 2019 | 08:41 PM
ironhead88's Avatar
My block is decked .020 and I'm using shim head gaskets, cause I wanted .035" squish clearance with rebuilder pistons
The .120" replacement gaskets are too thick
Old Jun 24, 2019 | 12:44 PM
InTech's Avatar
Nice gasket, I put it in my notes. Thanks,
-Carl
Old Jun 27, 2019 | 11:35 PM
ironhead88's Avatar
-Carl
I got the gaskets today
They aren't what their ad claims
They aren't steel core laminated, they're sort of rubberized fiber with silicone beads. I hope they work
Old Jul 2, 2019 | 07:51 PM
InTech's Avatar
How did those gaskets work out?
-Carl
Old Jul 3, 2019 | 08:29 PM
ironhead88's Avatar
-Carl
It will be a week or maybe 2 before I use them.
I'll try to remember to let you know
The question is, whether they'll withstand the test of time
Veaceonee
Jan 19, 2013 10:19 PM
KnightmareCS
Jul 5, 2012 12:16 PM
Wayquick4u
Nov 13, 2000 01:59 PM
