Faulty MAT Sensor
Old Jul 5, 2019 | 01:17 PM
JohnKimble86's Avatar
Car: 89 Camaro RS - White w/ Orange
Engine: 305 V8 TBI
Faulty MAT Sensor
I apologize ahead of time if this was answered somewhere else, but I've been struggling to find an answer.
Background: Recently purchased an 89 Camaro 305 V8 TBI. Since owning, I've replaced the Fuel Pump, Filter, and Fuel Relay. Car was running great. Ran into an issue recently where the car starts to choke out when accellerating after the car was warmed up. I replaced the MAP sensor under the guidance of my mechanic, but that did not help . I pulled the plug on the MAT Sensor (behind the air filter) and the problem has gone away. Problem I have now is that the check engine light comes on now once the car warms up. The other problem I have is that I can't find a replacement sensor. Are there any recommendations on what sensor I need to purchase to replace the bad one. I can add a photo later if that would help.
Old Jul 5, 2019 | 02:43 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Let’s Map It Out
MAP and MAT terms are frequently swapped.
If you can post a photo, that will clear it up.
Happy Racing !
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Old Jul 5, 2019 | 02:57 PM
Re: Faulty MAT Sensor
MAT = Manifold Absolute Temperature
MAP = Manifold Absolute Pressure
MAT is usually referred to as IAT Intake Absolute Temperature.
AFAIK TBI doesn't have a sensor for that... might be why you're having trouble finding one.
TBI doesn't have a choke. That's something carbed cars used to have. Whatever your car is doing, it's not related to "choke".
What color are the wires going to whatever you're disconnecting? How many in the plug? Where is it EXACTLY? What code do you get when you hook up your OBD1 scanner and read the codes?
Old Jul 6, 2019 | 12:39 AM
GeneralDisorder's Avatar
TBI, as with all forms of speed density that I'm aware of, has an IAT (Intake Air Temp) sensor. It does not have a manifold temp sensor...... though in the world of 80's/90's GM fuel injection they are pretty much always the same thing. Some are threaded, some are plastic push-in, and some are brass tip while others have a bird cage but they all share the same resistance values and wiring connector. Coolant temp, manifold temp, air temp.... same same.
GD
Old Jul 6, 2019 | 11:35 AM
Engine: 305 V8 TBI
Here's some photos. I haven't gotten a chance to pull the engine code yet. The sensor I disconnected is the round one seem in the photos.
Old Jul 7, 2019 | 11:10 AM
LIB; I'm sorry, I was misshapen, I guess these cars DO have an IAT sensor.
That one looks kinda like it's missing something. Might have something to do with why it doesn't work right.
Try searching for IAT sensor. Might also be called "air charge sensor", "air cleaner temp sensor", or various other names along those lines.
Old Jul 7, 2019 | 11:20 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Jul 7, 2019 | 02:05 PM
Engine: 305 V8 TBI
Thanks for finding those parts. Are you saying that I need both parts?
Old Jul 7, 2019 | 02:08 PM
You need the top one.
The other 2 are the coolant temp sensor. It goes into the intake manifold (INT MANIF) which might be why the search term "intake" pulled them up.
I'm NOT saying of course, that you DON'T need the other; you might, for all we know out here; only, that the one you showed, is a thing unto itself and is not involved with the other.
Old Jul 8, 2019 | 10:36 AM
Engine: 305 V8 TBI
Thanks for the help. I ordered the part. I'll report back in once it's installed.
Old Jul 12, 2019 | 08:00 PM
Engine: 305 V8 TBI
I replaced the sensor and the car runs better and I no longer get a check engine light. I seem to be in business. Thanks for the help, folks!
Old Jul 12, 2019 | 11:23 PM
jac113
Aug 22, 2011 05:25 AM
1988-305-tbi
Aug 8, 2007 07:47 AM
drive it
Mar 11, 2005 04:16 AM
fieromerk
Dec 25, 2001 05:13 PM
marald
Dec 11, 2000 02:53 PM
