'86 305 Power steering dedicated belt - Required?
Old Aug 8, 2019 | 10:13 AM
KnightZero's Avatar
Car: 1986 Pontiac Trans Am
I've traced down an odd rattle under the hood of my '86 TA to the power steering pump belt, the one that goes directly to the crankshaft pulley. It seems that the belt has lost some of it's spring. There's still a good belt on the second track, going from crank/waterpump/AC compressor/Power Steering. My question is, could I survive without that secondary belt to limp the car 30ish miles over to a buddy's house where I can actually wrench on it? I plan on replacing all the belts, but can't do so in the apartment parking lot, I figured I'd ask here before I make a terrible decision and snip that stretched belt off.
Old Aug 8, 2019 | 10:59 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: '86 305 Power steering dedicated belt - Required?
If it's only somewhat loose I'd be inclined to leave it till you get to where your going to work on it . If it's really bouncing bad and you think it may break or otherwise fall off and perhaps take out the good belt then yea , snip it off and hope the other belt stays put . Since you say it's dedicated to the power steering I'd avoid turning the wheel to it's stops (It's loading the pump more at the stops) to make sure the one good belt doesn't slip .
yevgenievich
Oct 21, 2017 12:22 PM
3.1EyeCandy
Mar 4, 2003 12:40 AM
88IROC350TPI
Jul 31, 2002 04:41 PM
Demon Z28
21
Jul 26, 2002 02:12 PM
DiecastZ28
Theoretical and Street Racing
Dec 3, 2001 11:02 AM
