do the tranny and the motor run off of the same computer?
Old Jan 11, 2002 | 12:08 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i gotta 84 ta with the q-jet on it
and i was wondering if i could somehow disconnect my computer from the motor so i can put a vacuum advance on the distributor and also so i can put it to what timing i like it at
if this is possible could you please tell me what i have to do to disconnect it
or if you think it will screw something up
thanks
Old Jan 11, 2002 | 09:45 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
The only thing the computer controls on your tranny is the TCC. If you disconnect it, your tranny won't lock up above 30-40 mph and you will get worse gas milage.
Also,(I may be wrong) but isn't the q-jet computer controlled? Wouldn't you have to get a non-computer controlled carb?
Old Jan 11, 2002 | 10:56 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah thats what i figured it did with the tranny
yah the stupid carb is computer controlled, dont really know what it does but i know there are some wires that hook up to it
jhawkeye
May 25, 2022 06:33 PM
camaro11j
Sep 19, 2018 08:49 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Bradsaundry
Aug 12, 2015 12:34 AM
