what does this mess do
Old Jan 11, 2002 | 10:41 AM
silentneko's Avatar
hey guys,
I have an 87 trans am with a factory carb. my question is what do att the hoses right on top of the engine to, the ones in front of the carb with the plastic valves on them and retainers......... can I remove this or will it effect my options and torque converter. or is it just for emmisions. thanks
Old Jan 11, 2002 | 02:08 PM
silentneko's Avatar
if no one knows then I guess its not really important enough to stay in my engine bay
Old Jan 11, 2002 | 04:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's part of the charcoal canister purge system.
If you remove it, you'd better have a good understanding of how to vent your gas tank and provide atmospheric pressure to the float bowl.
Rather than remove it, consider moving it to an out-of-the-way location.
Old Jan 11, 2002 | 04:26 PM
five7kid's Avatar
Oops, double post...
Old Jan 12, 2002 | 03:17 AM
Jza's Avatar
Jza
Nevermind, I'm probably not in the right mood to write something like that and just better off not saying anything...
Old Jan 12, 2002 | 04:02 PM
silentneko's Avatar
so if I move it out my car will first run crappy then blow up? man that sucks, how can I move it and to were?
Old Jan 12, 2002 | 04:32 PM
Vader's Avatar
Connect everything like this and it should run fine:
Old Jan 12, 2002 | 05:00 PM
silentneko's Avatar
how do these guys with the 383 with a holley make there engine look so simple. I just want my hood to open and a nice clean and simple engine to sit there, also simple so I can fix it. I'll never get it that way with the limited carb knowlege I have, what happens if I just plug the gas tank into the canister, my carb gets messed up?
F-body-fan
Jan 12, 2023 01:49 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
mrbird
Oct 20, 2015 03:43 AM
