Gauge doesn't read full?
Old Sep 26, 2019 | 07:27 AM
JBIroc87's Avatar
Hey, guys. I have an 87 Iroc z 5.7 TPI. When I fill up the tank the gauge reads 3/4, it never gets to full. I switched out the sending unit, pump, and tank and I still have the same issue. I believe I tested the gauge correctly and it checked out. What else could cause this? Thanks.
Old Sep 26, 2019 | 07:31 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Gauge doesn't read full?
The needle could be off or the contacts on the back of the gauge to the printed circuit could be corroded. Had it happen to a couple of my cars, I pulled the cluster and cleaned all the contacts from main harness and gauges to printed circuit. It all worked like a champ after.
Old Sep 27, 2019 | 10:43 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
FSM pages attached. Essentially, it's a process of elimination. If it's not the gauge, it's the sender; provided the wiring isn't hacked.
The instructions call for the use of a resistance box to check the gauge. Most people don't have a resistance box - you should be able to figure out a work around.
broke91firebird
Jun 4, 2015 01:45 PM
Laugh-Master!
Feb 26, 2014 12:04 PM
my90bird
Oct 27, 2010 10:16 PM
my90bird
Sep 30, 2009 11:47 PM
AlbertaFbody
Apr 14, 2004 03:23 AM
