SMOKE OUT TAILPIPE
Old Oct 19, 2019 | 04:55 AM
602azcardinal's Avatar
Car: 1985 Iroc
SMOKE OUT TAILPIPE
I have a 85 iroc that has a little smoke coming out the tailpipe either at initial startup or when it’s been setting at idle for awhile. I’m not mechanical and Wanted to see if you guys have any suggestions as to what it may be. It also passed emissions a few weeks ago doing the same thing.
thanks
Old Oct 19, 2019 | 05:12 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: SMOKE OUT TAILPIPE
This issue is typically caused by old / worn valve seals in the heads.
Old Oct 19, 2019 | 05:28 AM
Car: 1985 Iroc
Thanks you
Old Oct 19, 2019 | 07:22 AM
Yup; odds are, it's valve guide seals. A universal problem with this kind of engine (SBC) in its old age.
Old Oct 19, 2019 | 07:26 AM
Car: 1985 Iroc
Okay thought it may be head gasket but it’s not a lot of smoke....should I have head gasket replaced as well when doing valves?
Old Oct 19, 2019 | 08:15 AM
No.
Not a head gasket.
Not "valves" either; just, valve guide seals. A relatively trivial matter to repair.
Not sure about "have"; should be more a matter of just "do".
Old Oct 19, 2019 | 08:21 AM
Car: 1985 Iroc
Oh okay sorry my mistake
Old Oct 19, 2019 | 10:39 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
borrow a small air compressor get the tool from summit to pressure ea cyl
Make sure both valves are closed...then with a $8 manley valve spring compressor pull your springs, replace your seal (may as well do springs they are cheap) then move to the next cyl. Problem solved, no need to pull the heads.
Old Oct 19, 2019 | 11:19 AM
Car: 1985 Iroc
Perfect thank I will try that
Old Oct 19, 2019 | 02:57 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Make sure the oil drainage passage in the valve area is clear. If oil is pooling in that area it will exacerbate the problem. One of mine were clogged and after cleaning it out I can't see any smoke at all now.
Old Oct 19, 2019 | 03:36 PM
Car: 1985 Iroc
Thank you guys so much
kendl77
Mar 21, 2011 09:40 PM
Anisen
May 16, 2010 08:19 PM
ryguy85
Aug 11, 2004 01:07 AM
89transam
Southern California Area
Nov 25, 2002 01:05 AM
89Iroc-ZL98
Jun 3, 2002 02:40 PM
