Need some help
Old Oct 29, 2019 | 08:46 PM
Pierce52208's Avatar
Need some help
So I bought a 84 Firebird about 2 months ago, it has the 305 and the gentlemen said a 200 -4r tranny. My expertise is hardly in the wrench turning aspect of things, I am the appearance guy. I have completely restored the interior with everything new, have the car prepped for paint and plan on painting it this week. My plans are to move on to the Engine/Powertrain in December. I have found several 383 strokers that are so called "turn key" that I am considering, I have read that the 200-4r will handle the power and torque with ease if I upgrade it properly. Is this true and what would an estimated cost of upgrade be? Do I need to upgrade gears/rear end? Basically this is all foreign to me so any advise is appreciated
Old Oct 29, 2019 | 10:00 PM
Re: Need some help
It most likely doesn't have a 200-4R. These cars in the configuration you mention never came with that.
More likely it's a 700.
Step the 1st is to correctly identify what you've got.
https://www.google.com/search?q=gm+t...w=1344&bih=966
Old Oct 30, 2019 | 07:38 AM
Re: Need some help
You are correct, I just looked and it is indeed the 700. So then that should be able to handle a 383 with no problems correct?
Old Oct 30, 2019 | 01:12 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Need some help
yep,should be good-if it goes wrong,just pull it out for repair/ replace-pretty easy job on a 3G.700 had some upgrades in 1984,original tranny in a 1984 model could be 27 or 30 spline input shaft.
Old Oct 30, 2019 | 05:49 PM
Re: Need some help
I'm not going to go out on a limb and say that YOUR 700 will handle anything in particular "with no problems". But yes in general, a 700 CAN BE adequate for a 383.
Pierce52208
Oct 30, 2019 12:56 PM
1985WS6transam
Jul 6, 2007 08:37 AM
Zyth01
Nov 29, 2006 12:59 PM
johndukewayne
Oct 29, 2005 02:29 PM
