Tech / General EngineIs your car making a strange sound or won't start? Thinking of adding power with a new combination? Need other technical information or engine specific advice? Don't see another board for your problem? Post it here!
Of the two metal inlet pipes on the AIR pedes, one receives the rubber pipe from the converter and the other must receive the rubber pipes from the exhaust ports on each side of the engine; so basically I have to concoct a "T" or "Y" shaped connector so I can connect two separate pipes from the exhaust ports into one pipe on the AIR pedes, correct?
