New ignition coils - white powder in them
Old Nov 30, 2019 | 10:47 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Anyone know what this may be? Most of the coils I didn't notice this, but a few had it. These are brand new, out of the box. Was wondering if it is some sort of corrosion protection or if it should not be present at all?
Old Dec 4, 2019 | 01:10 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: New ignition coils - white powder in them
Pictures? I assume you're talking about ignition coils? Since you say coils and not coil, I assume you mean LS1 or other COP coils. I've seen white powdery residue in brand new ignition coils for some euro applications. I wonder if it's not some kind of dry lubricant on the boots. I apply dielectric grease to every coil or plug boot due to the high moisture levels in our wet climate. This excludes some of the euros(BMW) due to the tension fit and making sure they stay firmly in place. I've found that the grease makes them a little too easy to pull out. I don't think I've ever seen any white powder in any other coil. They usually come packaged in a sealed plastic bag inside the box. They come out bright and clean.
Old Dec 4, 2019 | 08:13 PM
LiquidBlue's Avatar
Transmission: MD8
Thanks for your reply Doc. Yes, I am referring to coils, and to your insight, specifically BMW N62 coils. I thought this was a generic question, never messed with coils before. My first trip. I was told elsewhere that it was used as a lube to get them into place as you say. What was weird was some of them had this, others did not.
Old Dec 5, 2019 | 10:45 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
It is odd that some don't have it. I used to apply dielectric grease to the BMW coils the same as I do all others, then I started to worry about them working their way out of the wells and stopped using the grease. If it were me, I would install them as they are and go on.
Old Dec 5, 2019 | 11:57 AM
LiquidBlue's Avatar
Transmission: MD8
ya, that's what I did with 1 or 2, then the remaining, I ended up blowing out as much dust as I could. I can't say that the talcum (or what ever it is) eases installation over a plain dry boot. not what I experienced anyway.
Old Dec 6, 2019 | 07:34 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
They should fit snug.
Old Dec 6, 2019 | 01:58 PM
LiquidBlue's Avatar
Transmission: MD8
oh boy did they! i ended up using a piece of wood to assist pushing them in all the way. another handy tool not commonly kept in the tool box
JimRockford
Aug 1, 2019 10:47 PM
Iluvspd
Dec 27, 2007 08:22 AM
89firebirdguy05
Apr 21, 2006 11:09 AM
redrummer
Apr 26, 2004 08:49 PM
GTA91
Apr 29, 2003 02:08 PM
