Best Oil? Carbureted '89 Firebird
Car: 1989 Pontiac Firebird
Engine: V8, CSM 305
Transmission: Stock (for now...)
Axle/Gears: Stock (for now...)
I know that Oil is a really important element for my car, and right now I'm using Valvoline 10W-30.
However, I've gotten some people telling me that Mobil 1 is a better option for carbureted engines.
How does a carbs needs differ from Fuel Injection in terms of oil?
Recommendations?
Thanks!
AvianWing
Recommendations?
Thanks!
AvianWing
Re: Best Oil? Carbureted '89 Firebird
Carbs like to foul the oil with tons of unburned fuel - especially on cold start. This leads to dramatically shorter engine life from fuel dilution and cylinder washing and there's really no oil that's going to stop it. Whatever you use it should be changed often. I would buy an inexpensive synthetic and change it at least every 2500 miles since this is obviously an aftermarket carb that likely has some pretty rich tuning and none of the 80's advancements such as the E4ME Q-Jet had that would reduce fuel dilution, etc.
Best thing you can do for engine life and oil life is put the fuel injection back on.
GD
GD
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Here in the 21st century, oil brands don't matter. Use the proper rating & viscosity, and change oil when it needs to be changed. The intervals depend on how the car is used, environment, etc. It's not a "one size fits all" number. I see no point in running a synthetic in a high-mileage engine, but that's just me...
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
EVery day this comes up on every forum. There is no magic oil period
Pricy cheap doesnt matter..as said keep it clean and use a good filter.
None will magically give you tons more life than the other. I run cheapo oil for my daily and a wix filter almost 200k and runs like a top.
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Advanced auto parts is clearancing out 10W30 Mobil Synthetic DIRT cheap
Dave
Dave
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
While none are magic is correct there are differences between oils that, depending on your usage, can make a difference.
Any "difference" is negligible...
Car: 1991 Z28 Vert
For a grocery-getter, sure.
I think you could stand to do some more reading on engine oil tests. Here are two quick and good reads by AMSOIL
http://wpc.1c96.edgecastcdn.net/001C...ml5/index.html
http://wpc.1c96.edgecastcdn.net/001C...ved/index.html
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
the consensus is "it isn't the type of oil you use" (and in older,higher mileage carbed vehicles i personally would not use synthetic)
" its the matter of changing it at or before the recommended frequency with an oil filter that DOES NOT SAY FRAM ON IT..."
(worst filters made,period)
CamaroHawke
Sep 23, 2010 06:48 AM
