MAF
Old Dec 14, 2019 | 03:42 PM
DIPDAVIS's Avatar
MAF
Can a 1986 2.8L firebird MAF be used in a 1986 2.8L camero ?
Old Dec 14, 2019 | 08:30 PM
Re: MAF
camero
Not sure... what IS that??
Old Dec 15, 2019 | 06:42 PM
DIPDAVIS's Avatar
Re: MAF
Wow you got my typo, I WANT TO THANK YOU FOR YOUR INCITE AND WISDOM IT REALLY HELPED YOU ARE A ROCK STAR ! I can fix my typo but no one can fix what you are
Old Dec 15, 2019 | 07:07 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: MAF
Originally Posted by DIPDAVIS
Can a 1986 2.8L Firebird MAF be used in a 1986 2.8L Camaro ?
I'm gonna go out on a limb here and say no , because Rock Auto lists the 86 Camaro 2.8 V6 MAF as AC Delco 2133447 and the 86 Firebird 2.8 V6 MAF as AC Delco 2133450 . Different numbers likely means there is some difference between the two , who knows , the difference may be subtle or totally unworkable , but since there is a difference you'd best stick to what the parts lists say belongs in your car .
Old Dec 15, 2019 | 08:30 PM
Re: MAF
Well, I'd rather be whatever I am, than someone who CAN'T EVEN READ THE LABEL ON THE SIDE OF THEIR OWN CAR.
That said Orange is probably right,. OTOH you could try it and see, who knows, you might get lucky. (well at least the MAF might work)
Old Dec 16, 2019 | 11:16 AM
DIPDAVIS's Avatar
Re: MAF
this is the car and I can quite well spelling a whole dif game
Old Dec 16, 2019 | 11:18 AM
DIPDAVIS's Avatar
Re: MAF
thanks for the reply there is a difference between how they are installed one the firebird has a 45deg housing and the camaro doesn't.
thx again
Old Dec 17, 2019 | 01:59 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: MAF
AFAIR, all 86 Camaros have air filters in front of the radiator. All 86 Firebirds have the air filter behind the right front headlight. The air intake tubes are different and thus the MAFs are different. The real problem with those 35 year old systems is finding a decent replacement MAF. I've gone through multiple from different suppliers looking for a single good one. Are you running a 1986 GM 2.8 V6 in the MG? If so, and it needs a MAF, good luck. You would be so much better off swapping up to a 3.1 or newer 3.4. Much better engine and if you go with the early 90s version electronics, it's speed density, no MAF sensor.
Old Dec 17, 2019 | 02:56 PM
DIPDAVIS's Avatar
Re: MAF
ran the 2.8L for 6 years replaced motor with an bored fiero motor having tons of trouble now. car runs good with the MAF disconnected. it is a transplant from an 86 Firebird
Old Dec 17, 2019 | 03:15 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: MAF
What are you doing for an air cleaner? Managing airflow into the MAF is critical to MAF accuracy. Having it laying open as in the photo could be part of your trouble. Be sure to check your circuits. The MAF sensor needs 12v from the relay, a good ground and signal path to the ECM. In your installation, I don't know that the Camaro MAF wouldn't work okay.
Old Dec 17, 2019 | 03:51 PM
DIPDAVIS's Avatar
Re: MAF
come to think about it I'm 1 engine ground short. What happen when the ECM goes to limp mode ? what gets shut down?
Old Dec 17, 2019 | 05:14 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: MAF
I like the ingenuity of putting the MG logo on the upper manifold , looks good .
And I'll bet that putter hood (Bonnet in the car's native language) prop isn't an approved Morris' Garage accessory ? .... !
TPI 85 Blazer
Apr 9, 2006 12:29 PM
Leo_padakin
Jan 28, 2006 11:52 PM
Doward
Dec 26, 2004 06:06 PM
Doward
Aug 15, 2004 10:44 PM
