Roller Cam (Upgrade?)
Old Dec 14, 2019 | 09:21 PM
Slow'86's Avatar
Car: 1986 IROC-Z
Engine: 6.0
Axle/Gears: 10 Bolt/3.43
Hello! New here. I've got a quick question concerning my 1986 LG4 block. I'd like to see about dropping in a roller cam set up, but I wasn't sure if that's possible. I see it has two "pillars" (see picture), that look similar to the '87-on engine's lifter retainer's bolt down spots. Would I be able to tap those two spots and install an OEM retainer?
Thanks!
Old Dec 14, 2019 | 09:45 PM
Drew's Avatar
Re: Roller Cam (Upgrade?)
It's not a roller block. You'd be further ahead to find another block, one with an extra 45 cu in. even.
Old Dec 14, 2019 | 09:59 PM
Slow'86's Avatar
Car: 1986 IROC-Z
Engine: 6.0
Thanks for the quick reply! Well, at this point I don't think retrofit rollers would be worth it, nor spending too much on this 30+ yr old block. Might just go for a newer 4.8, or an LT set up.
Goany
Sep 23, 2010 03:42 PM
noroxus
Jul 23, 2008 03:15 PM
n1ffer
Jul 10, 2008 04:49 PM
anubiscougar
Nov 14, 2003 12:26 PM
Motopsyco
May 30, 2002 07:19 PM
