Cam ?
Cam ?
Anyone here use an lpe219 cam by lingenfelter we are putting one in a 383 stroker I just liked that lingenfelter did a build years ago similar to what we are doing now...
Re: Cam ?
I wouldn't buy a LPE219 cam in todays age. There are newer cams using similar specs, but with better lobes that take advantage of the advances in springs and lifters since then.
If you've got the cam already then its not worth buying something else. But if buying out-right there are newer lobe designs on modern cams that will perform better with no downsides.
Re: Cam ?
