383 cam ?
Old Feb 6, 2006 | 01:30 PM
91Z28CAMARO32's Avatar
Car: 91 Z28 CAMARO
Engine: 383 STROKER TPI
Transmission: TH-700-R4
383 cam ?
what is the the biggest size cams u can put in a 383 stroker with out the valves hitting the piston cuz right now i have a 282/282 with a 480 lift is this a decent cam cuz i didnt pick it out the guy that built this says its a good size cam with mid range but id like to get more power out of this motor
Old Feb 6, 2006 | 02:02 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
you can use a much bigger cam. What are the numbers at .050 lift?
Old Feb 6, 2006 | 06:11 PM
Car: 91 Z28 CAMARO
i dont know the guy never evn gave me the cam specs
Old Feb 6, 2006 | 06:16 PM
Car: 91 Z28 CAMARO
wild cam
whats a good wild cam to put in my 383 with out giving me probs.
Old Feb 6, 2006 | 06:49 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Define "problems"
Old Feb 7, 2006 | 10:02 AM
Car: 91 Z28 CAMARO
WELL ID LIKE IT TO HAVE A NICE LOPE TO THE ENGINE BUT NOT WERE I HIT THE GAS AND STALLS OUT BECUASE THE CAM IS TO BIG
Old Feb 7, 2006 | 10:38 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
So Your not against a custome tune by a professional?
I like the XE series. Look into 12-443-8
294/300 advertised
242-248 @ .050
.576/.599 w/ 1.6 rockers
it's pretty wild and you'll need to check all your clearances, no one can tell you for sure. Also will probably need to machine your spring pockets to fit the required springs. I'd use at least a comp 987-16. This 443 cam is the new cam I'm planning on for my 355. A 383 will idle a little better.
Your TPI is hating life already. The heads probably won't like that cam either. But you didn't ask what would be the best one for your set up, just wanted to know what "big one" will fit. give bullitcams a try.
Old Feb 7, 2006 | 12:21 PM
Car: 91 Z28 CAMARO
Grind Number CS 280H-10
Description
MAGNUM 280H CAM FROM COMP CAMS
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.48 0.48
Duration At 0.006 Tappet Lift 280 280
Valve Timing At 0.006
Open Close
Intake 34 66
Exhaust 74 26
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 230 230
Lobe Lift 0.32 0.32
Lobe Separation 110
this is the cam i wanted to get but comp cams said the engine will not run so.......
Old Feb 8, 2006 | 03:13 AM
83 Crossfire TA's Avatar
Why not just have whatever cam you want ground on a small base circle?
As far as actual cam timing, you’d have to give a lot more information about what you have and what you want out of it before anyone is going to do much more then throw out big numbers.
What’s the deal with bullet cams? I’ve never gotten them to answer their phone and got no response to their online cam request.
Old Feb 9, 2006 | 01:02 PM
Car: 91 Z28 CAMARO
need cam recemendation for 383 stroker (anyone) somthing with low end and mid range power with a rough idle
Old Feb 10, 2006 | 03:39 AM
Hints don't work with you, do they?
Old Feb 13, 2006 | 02:43 PM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
Your not getting the repsonses you are looking for because we don't have enough information. We don't know deck height, what kind of heads you have, head gasket thickness, flow numbers for the heads, quench height, piston brand, piston style, etc...
All that information goes into selecting a cam. If you can get some more info, we can probably point you in the right direction.
The cam you have now sounds pretty tame to me; assuming your duration is the advertised duration, not the .050 duration.
Whatever cam you decide to go with, after the install, adjust the rockers with the engine off and turn the engine by hand. You should be able to feel any piston/valve contact as long as you are careful. It's not a sure fire means of preventing piston/valve contact, but it's better than nothing.
My reccomendation (based on knowing absolutely nothing about your engine other than it is a 4.030 bore and a 3.75 stroke) would be:
114 LS
.565 / .575
232 /242
Something like that should make decent top end power, and will be semi-easy to tune. If you have a competent tuner in your area you might consider dropping to a 112 LS. Of course, if your heads flow well, or poorly, the recommendation would change. This is 100% a shot in the dark without some more info.
Last thing, it's easy to spend other people's money on the internet. People are always going to give you thier own opinions, which may not be the best for you. The best thing you can do is learn about what makes a good cam for certain applications, and why. Then you can make up your own mind, and choose a cam that will do exactly what you want it to.
Jorlain
Oct 8, 2015 01:57 AM
abray1
Sep 10, 2015 04:53 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
