L98 best heads to match torker high rise manifold and Holley 1050 dominate carb
Car: 91 z28
Engine: 350 tpi
Axle/Gears: Solid 3.73 posi unit
I have 2 questions.I bought a torker high rise manifold I wanted to get rid of the tpi and was wondering if a set of trick flow 2.02 195s would bolt up to these or not.if not what aftermarket heads would and will a Holley 1050 dominator pump too much gas and air into the motor?
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: L98 best heads to match torker high rise manifold and Holley 1050 dominate carb
BTW, a 1050 Dominator, which is a race-only carburetor, won't bolt onto a Torker manifold.
CKone (01-15-2020)
Is this a joke, or did someone use Google Translate to post this string of questions?
T98 High Growth Manifold and Holley 1050 Carburetor L98 Head
I have two questions. I bought a lot of high growth torso. To get rid of Tpi, there is no doubt whether the tricky 1952 stream is 2.02195. What will market leaders want next, and will Holly 1050 want it? Do you pump too much gas and air into the motor?
Car: 91 z28
Engine: 350 tpi
What intakes will bolt up to a set of super 23 195s then?
Car: 91 z28
Engine: 350 tpi
Already found a set of heads thanks
