transmission break down quick question
Old Jan 23, 2020 | 08:40 PM
J_question's Avatar
So I have to remove my VSS which isn’t a huge deal. Only issue is only the sealed part is still inside and the insides are removed .
What is left inside the tranny (700r4)
does anyone have any ideas on getting this out? Also , will I lose a lot of transmission fluid in the process? And will the gear for the sensor fall into the extension housing? I am not highly experienced by any stretch in the car world so these are me trying to understand. If you have any questions about what I’m askin just leave them below I check on this a couple times a day
Old Jan 23, 2020 | 09:13 PM
Drew's Avatar
Re: transmission break down quick question
Sure. Pull the tail shaft housing, and push it out from the inside.
Old Jan 28, 2020 | 05:46 PM
J_question's Avatar
but will it leak a ton of transmission fluid?
Old Jan 28, 2020 | 06:07 PM
You'll lose "some" but not "a ton". A few ounces at most. Just have your drain pan in place before popping the ext hsg off.
Old Jan 29, 2020 | 07:41 AM
J_question's Avatar
thank you that was my biggest concern really!
chas0218
May 6, 2010 03:44 PM
palmcoastpimp
Feb 19, 2008 01:30 PM
V8Rumble
Sep 7, 2007 11:32 PM
DigitalMonarch0
Feb 15, 2005 07:53 AM
