305 to 350
Old Jan 13, 2002 | 12:12 PM
PimpCamaroRS's Avatar
305 to 350
i plan on dropping a 350 crate motor in my 91 RS. i Live in CA so it has to pass smog. I am keeping the cat on but how do i get it so my smog pump and all those gay little things work. pretty much what i am asking is what does my smog pump and all those tubes connect to?
Old Jan 13, 2002 | 12:30 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I'm not so sure I understand what the question is, but all the smog stuff will just swap over to the 350 no problem.
just hook everything up as it was on the 305.
Is it all disconnected and you need to know where it goes??
One thing, when you go to get it smogged, make sure you don't say its a 350 now. As far as the smog ***** are concerned, its a 305. (you would be amazed how many people cause problems for theirselves by telling the smog people its a different motor)....
Old Jan 13, 2002 | 11:52 PM
wel like when i order a crate eninge do i have to specify anything so itwill work with my smog stuff
Old Jan 14, 2002 | 09:27 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have a 92 RS, that came with a 305 TBI motor and 5 speed trans. Swapped in a 300HP 350 crate motor last summer (from goautocenter.com).Just brought over all the accessories from the 305, except for the injectors,knock sensor and module (from 350 TBI truck).You may also need a chip change.
I can give you all the part#'s if you need them.E-mail me.
With the single snorkel air cleaner installed, my car still passes smog in California as a 305.
-Rich-
Old Jan 14, 2002 | 10:45 AM
hey what is the module. i knew about changeing the knock sensor, injectors, chip(possibly) but never heard of having to change the module. what is it and how mcuh they run? thanx
Old Jan 15, 2002 | 12:00 AM
i know i sound dumb but this is crap i need to know
Old Jan 15, 2002 | 12:22 AM
Momar's Avatar
It is the electronic spark control module. It helps control the timing and I believe it translates the signal from the knock sensor to the computer. Some people say it is not necesary to change but if you want the best performance and drivability I would do it so that you have the right thing. I believe that you can use the one for the 350 tpi.
Ben
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
