Need help with serpentine belt conversion..
Old Mar 27, 2020 | 06:01 PM
Ct1987's Avatar
Hi, I am in the process of converting my 1987 Formula 305 engine from belt to serpentine. I have all the brackets from a 1989 formula. All the brackets fit perfectly. I was not able to get the damper pulley, so I bought a new GM 6 rib pulley, part number - 10085754 I installed it today and it appears to be too short, at least by 1/2 inch. It does not line up with the other pulleys
Has anyone who has done this conversion had this problem. If so, how did you remedy it? I assume if all else fails, I can put spacers behind the pulley to bring it out.
Your thoughts anyone.
Thanks,
Louis
Old Mar 27, 2020 | 06:14 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Need help with serpentine belt conversion..
Don't add spacers behind the pulley, I suspect you have the wrong pully, give me a few minutes, I have the one off of the '89 here, I'll mesure it and post up for you to compare.
Old Mar 27, 2020 | 06:17 PM
Ct1987's Avatar
Thanks Mike, appreciate it.
Louis
Old Mar 27, 2020 | 06:19 PM
Drew's Avatar
10055879 should be the one you need.
The GMPP serpentine kit is the thirdgen setup, you can usually find the kit contents list with part numbers with a Google search.
https://paceperformance.com/i-625526...-with-air.html
Old Mar 27, 2020 | 06:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
So my pulley is about 3 1/4 inch, laying rib side down, tape measure in the hole to the mounting face. Let me know what your's is. Could be possible a different HB is needed, but I don't think so.
Edit:
Looks like Drew has ya covered!
Old Mar 27, 2020 | 06:24 PM
Drew's Avatar
From Summit's applications list for 10085754, it sounds like the pulley you have is the one that fits trucks from 87-2003, like 4.3L S-trucks, Astro vans, etc, ie the other serpentine setup. The car setup is different.
Old Mar 27, 2020 | 06:34 PM
Ct1987's Avatar
Drew, Mike...thanks for your help. Mike, what is the part number on the pulley that you have?
Louis
Old Mar 27, 2020 | 06:42 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Louis
GM says....
10055879 AAD
Old Mar 27, 2020 | 06:43 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
See, Drew had ya covered!
Old Mar 27, 2020 | 07:12 PM
Drew's Avatar
Yeah, but I cheated using Google. If I'd walked down the hall and grabbed the pulley off the shelf, you would have beat me to the reply. I didn't even think to look at the number on a pulley.
Old Mar 27, 2020 | 07:14 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Lol. Luckily the beer fridge is in the shop, just outside the door. Damned, if Summit would deliver soon, I could forgo a few for a bit
RedneckNo4
Oct 3, 2016 01:06 AM
AC
Fabrication
Nov 29, 2009 02:22 PM
RiggsLW81
Apr 20, 2008 11:42 AM
cort351w
May 16, 2002 01:07 PM
stevenmh
Nov 14, 2000 08:26 PM
