Replacement heater core options???
Old Mar 27, 2020 | 09:22 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Well the original looks to finally be on its way out, found a few drops of coolant on kick panel when checking PROM chip. Any recommendations for a quality replacement?? I would like to avoid the spectra because I’ve read on here of poor fitment. I see Hawks sells one but it’s double the rock auto offerings and am curious if anyone has tried it? Any feedback is appreciated as I have heard the aftermarket ones are not great.
Old Mar 27, 2020 | 09:25 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Replacement heater core options???
Get your original re-cored
Old Mar 27, 2020 | 09:52 PM
Engine: 5.7 L98
That would be ideal, the thing threw great heat in the limited fall use it saw, the aftermarkets don’t put out as much heat I heard and fit is not good either. I will check around my area for a radiator shop, I’m in the sticks but might get lucky.
Old Mar 27, 2020 | 10:52 PM
Drew's Avatar
It wouldn't surprise me if all the aftermarket cores are coming from the same factory. Some people have had reasonable results using the aluminum replacements. You might get lucky when you remove the existing core, it might just have a broken solder joint, or a pinhole leak in a spot that can be repaired without a recore. Sometimes the joints where the tubes meet the end cap like to crack, in which case it's easy enough to heat up the joint with a torch and reflow the solder. If you have any doubts, try to find a radiator shop to do the work for you.
Old Mar 28, 2020 | 09:38 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
I ordered spectra and vista-pro cores,neither fit without hacking core panels,so I ended to resolder original core pipes->hassle free installation.
Old Mar 28, 2020 | 06:17 PM
Engine: 5.7 L98
I emailed Hawks to see what they had to say in regards to the heater core they sell that supposedly has 2 extra accessories that makes install very easy. Will let you guys know what I find out. Also got the name of a local radiator shop that I’ve heard good things about, will have to check with them as well.
Old Mar 30, 2020 | 04:35 PM
Engine: 5.7 L98
Called a local radiator place who said he can't even get the materials to re-core the original so that's out especially with the current situation I am not gonna travel far, also never heard back from Hawks (upon closer inspection it looked like a Spectra anyway), but I hit eBay hard and found a new old replacement stock heater core for it for around $43, looks like an old 4 seasons brand still in the box and it looks exactly like the original judging by photos. If anyone is interested there were also several used originals as well on there for prices ranging $20 to $100.
Tootie Pang
Sep 17, 2018 07:54 PM
vbMike
May 4, 2018 09:40 PM
72SSboy
Sep 8, 2013 07:23 PM
88fastgta
Sep 7, 2009 09:45 AM
packerz_fan1
Mar 23, 2005 11:43 AM
