Laboring idle
Old May 27, 2020 | 05:07 AM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
Laboring idle
If I don't allow my car to warm up the idle labors to keep it running when I put it in gear. Otherwise it runs fine. If I let it run for about 10 min before driving it's fine with a normal idle. I haven't pulled engine codes yet. My " guess" is a fuel pump. Who knows at this point.
Old May 27, 2020 | 11:29 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Laboring idle
Fuel pump wouldn't be on my list of things. I'd look at vacuum leaks and test the coolant temperature sensor first. Then go from there.
Old Jun 9, 2020 | 06:52 AM
Evilokc's Avatar
Engine: tbi 305
Re: Laboring idle
coolant temp sensor huh/. hadn't thought of that. this will be my weekend project. hope its simple.
Old Jun 9, 2020 | 08:44 AM
Evilokc's Avatar
Engine: tbi 305
Re: Laboring idle
I ran out and poked around. the vacuum line on the map sensor in broken. im not even sure where the other end of that hose is. I plugged it and the problem was corrected. I will do a little research and replace that vacuum line and it should be good to go.. honestly all the vacuum line in this car are brittle. I need to make a project out of replacing all the vacuum lines. anyone know where a good diagram for a 305 tbi vacuum system is?
Old Jun 9, 2020 | 09:36 AM
Re: Laboring idle
I know where one is. On these boards. Search and done.
https://www.thirdgen.org/forums/tech...iagrams-i.html
Old Jun 9, 2020 | 10:37 AM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
Re: Laboring idle
This was my major culprit, after I installed a new vacuum canister due to a broken vacuum line nipple on the canister itself.
Old Jun 9, 2020 | 06:22 PM
Evilokc's Avatar
Engine: tbi 305
Re: Laboring idle
thanks man I appreciate that
Old Jun 14, 2020 | 09:56 PM
Evilokc's Avatar
Engine: tbi 305
Re: Laboring idle
replaced the vacuum hose. seems to have corrected the issue. I didn't drive just put it in gear in the driveway. seems fine though.
Old Jun 16, 2020 | 07:36 AM
Evilokc's Avatar
Engine: tbi 305
Re: Laboring idle
I`ve driven the car to the gym the last two mornings. the vacuum leak seems to have been the issue. its running much better now. the car no longer tries to die at a stop. the idle has never been great and I noticed that the tach needle still moves a tiny bit at idle. that means I probably have another vacuum leak somewhere. I will start searching for it.
Zerocyde
Carburetors
May 19, 2011 06:31 AM
bcrz28
Nov 25, 2004 11:52 AM
joker37
Sep 23, 2004 08:38 AM
