Excess Play with Comp Rockers?
Old Jun 10, 2020 | 07:55 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I put together a 350 for my car a few months ago. Wound up getting it into the car, engine runs strong. On driving it I noticed a noise seemingly coming from the valve train. From the get-go I was skeptical that the way these rockers moved around on the valve tip was right, but I didn't really know better. Now that I'm hearing the noise and really seeing how these are moving the valves, there's no way this can be right. Input is appreciated. Heads are AFR 180cc, 3/8 screw in studs with AFR supplied guideplates. Pushrods are Comp 5/16 7.2" length. Rockers are Comp 17002-16 3/8 mount. Rockers were set 3/4 turn past 0 lash.
Old Jun 10, 2020 | 08:09 PM
BIRD91ZRAG's Avatar
Re: Excess Play with Comp Rockers?
Maybe you have guide plates for 3/8 pushrods?? That's a lot of play. Check to see how much clearance there is between the pushrod and the guideplate.
Old Jun 10, 2020 | 09:15 PM
Engine: LB9, LS1
With the pushrod up against the guideplate on one side I have .012" clearance on the other side. The movement is not nearly as extreme on the pushrod side. The rockers seem to move around on the shaft itself.
Old Jun 11, 2020 | 07:39 AM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
I had the same rockers on a 305 the ticking drove me nuts! I put stock ones back on and noise went away. They have alot of sideplay I was expecting better quality with comp. Years ago I had cheap proforms and had zero noise from them.
Old Jun 11, 2020 | 10:13 AM
GeneralDisorder's Avatar
I have a set of those and wasn't impressed with the appearance or finish work on them. Didn't use them. Went with Scorpion and am very happy with them.
GD
Old Jun 12, 2020 | 08:48 PM
Vader's Avatar
Originally Posted by NowhereFast
With the pushrod up against the guideplate on one side I have .12" clearance on the other side. The movement is not nearly as extreme on the pushrod side. The rockers seem to move around on the shaft itself.
That's nearly an eigth of an inch (0.125). That can't be right. It might be a good idea to contact the supplier to inquire about their tolerances.
Old Jun 13, 2020 | 09:10 PM
Engine: LB9, LS1
Sorry, that was mis-typed. .012" is the clearance.
t.p.engineerin
Nov 2, 2010 04:31 PM
IrocZ'85
Jul 26, 2010 10:17 AM
LB9GTA
May 10, 2007 01:30 PM
89formula35O
Jun 27, 2003 12:08 AM
CoopDog
Jun 8, 2003 09:57 AM
