1988 IROC - stripped oil pan thread
Old Jul 18, 2020 | 07:14 AM
Luvchevs's Avatar
New to the forum, looking for some help.
Any suggestions how to fix this without replacing the pan?
I have the 305 TPI engine.
Anyone know for sure the drain plug thread specs?
I put an expandable rubber plug in as a temporary fix but it is leaking for sure and not a permanent solution.
Old Jul 18, 2020 | 09:24 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: 1988 IROC - stripped oil pan thread
Here's my thread:
https://www.thirdgen.org/forums/tech...d-oil-pan.html
There's been some discussion but those threads can be hard to find. The stores sell a self tapping drain plug that cuts into the existing, stripped hole with a slightly larger one. They are only a few bucks. However, I found this was not a permanent solution either. I ended up buying a larger tap and heli-coil set and a new, next size up drain plug that I will install at the next oil change.
Old Jul 18, 2020 | 09:52 AM
GeneralDisorder's Avatar
https://www.timesert.com/html/drainplug.html
GD
Tootie Pang
Mar 27, 2020 07:22 PM
Zap Racing
Jun 11, 2005 07:24 AM
Randy_M
Mar 21, 2005 07:59 PM
H-BOMB
Dec 16, 2003 04:54 AM
dsaint1347
Nov 1, 2003 10:46 AM
