Charcoal Canister Alternative?
Old Jul 22, 2020 | 01:04 PM
IRocN87's Avatar
Car: 87 Iroc w/ T-tops
Engine: LB9
Hey yall, I've been doing some research about replacing / removing the charcoal canister on my car, but haven't really found a definitive answer for my idea. I see lots of people claim to just cap the vacuum line, put a filter on the end of the hose from the tank, and switch to a vented gas cap. I don't really want to do this... However, is it possible to remove the canister, but keep the purge valve's vacuum & fuel line connected to the throttle body, having the fuel vapor go through a fuel filter such as
this one? this one?
What consequences would this cause to idle and drive? (As this would no longer cause the system to be computer controlled).
Lastly, for anyone who might say to just leave it intact; I was cleaning up around it and discovered a bunch of little white mites have decided to make the canister their new home... with no way to properly clean it, figured it was time to ditch it and rig something else up lol.
Old Jul 28, 2020 | 12:19 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Charcoal Canister Alternative?
Rebuild it.
https://www.thirdgen.org/forums/tech...ebuilt-my.html
Old Jul 29, 2020 | 08:07 AM
kestell123's Avatar
Car: 1991 camaro convertible
Engine: LS3
Transmission: 6l80
Axle/Gears: Ford 8.8 3.31 torsen t2r
When I did ls swap with a 5.3 I used TPI air filter system and kept the charcoal can operational in it's stock location. When I switched to an LS3 I did not think the TPI air box would flow enough for that engine. I then used a cold air intake that placed the filter in the space where the charcoal can originally was and move the can under that area behind the bumper. If it were me, I would replace or rebuild and keep the system functional, If for no other reason than to limit the gas odor in the garage.
Old Jul 30, 2020 | 11:53 AM
IRocN87's Avatar
Engine: LB9
Okay, thanks guys. In favor of not effecting anything on the car, I will look into a diy rebuild.
xbox07
Carburetors
Sep 27, 2009 10:31 PM
87iroczeh
Jun 8, 2009 12:04 PM
xlwhellraiser
Apr 9, 2006 04:58 PM
zach
Jun 28, 2002 12:40 AM
86TpiTransAm
Apr 24, 2002 08:27 PM
