LT-1 Cam???????
Old Jan 15, 2002 | 03:09 AM
Dans91's Avatar
Car: 91 RS
LT-1 Cam???????
I am going to buy a LT-1 cam for 20 bux, now what do i have to do to my 91 305 (TBI) motor to swap this,
Do i have to put in new springs, new valves, do i have to change out my hydraulic lifter,
Any help would be awsome
Thanx
Dan
Old Jan 15, 2002 | 09:54 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the front of the cam has a drive pin for the dist
you can remove it and I think it will work otherwise.
You can probably use the old springs.. just shim them a little..
But, a cam swap is a good amount of trouble.....i don't know if I would go stock LT1 cam if I was going to do it.
Old Jan 15, 2002 | 03:23 PM
Z-Man 85's Avatar
I have heard the LT1 cams work good with TBI cars. I don't know the specs on them, but I do know that alot of people are running 'em. Are you sure you have hydraulic lifters, they should be roller lifters. I don't think you'll need new valves.
Old Jan 15, 2002 | 03:38 PM
85transamtpi's Avatar
As Z-Man said, you have roller lifters that should not have to be changed. Your springs MAY need to be changed...it couldnt hurt, but it's a pain in the @ss to change them without taking off the heads. If you pull those swirl port heads at all you might as well replace them (they suck!). Heres what I would use...
New Timing chain
Gasket
RTV
Cam
Thas about it. You should get quite a performance gain compared the the weenie L03 cam.
-peace
Old Jan 15, 2002 | 09:14 PM
camaro6spd's Avatar
I have the Swirl port heads on my IROC(I got a Brand new truck motor for 900) and they are not too bad.....I suggest that you hold off for a month or so and buy some used LB9(305TPI) heads and get a valve job done to them around $200. Then you would have much bigger gains, but If you are just looking for a cam swap, just do that and forget the heads....maybe take yours and clean them up with a dremel, do some port matching(free if you have a dremal) while everything is apart......again bigger gains.....
Old Jan 16, 2002 | 01:35 AM
Dans91's Avatar
Car: 91 RS
Thanks everyone, Man i swear what would i do without this site. My life would consist of going to the library and looking in Kamasutra books all day long
No on the serious side i do appreciate all the answers and i am going to get my heads ported and polished as soon as i get the moolah, if ya know what i mean
Thanx alot
Dan
Old Jan 16, 2002 | 10:18 AM
camaro6spd's Avatar
well you I would not GET them ported and polish unless it was free or next to nothing.....If I was to go that rought, LB9 heads would be in order....I have a set from my 87 TPI 5spd.....I may be interested in selling them.....they will need a valve job....but come complete with LB9 valve springs and Valves....They are un damaged. Hell you could ru them as is but I would reccomend a valve job.
Old Jan 16, 2002 | 12:43 PM
Listen to Camaro6spd
DO NOT WASTE ANY MONEY ON THOSE HEADS
Do what he says and get some used LB9/L69 heads. They are a much better design. You can port them yourself for next to nothing, and a 3 angle valve job is pretty cheap. This would make a pretty big difference in your performance, even if you didnt change the cam.
I say change the heads and the cam
It will feel like a new car
-peace
Old Jan 17, 2002 | 01:35 AM
Dans91's Avatar
Car: 91 RS
camaro6speed====What did you say the heads came off of, if they came off a 87 305 TPI, I still dont think i can run those heads do to the different intake bolt patterns, in fact i am pretty sure of it, if i can use those on my block how much $, my e-mail addy is Dans91@teamcamaroz28.com
or
daniel_sarandos@hotmail.com
Hit me up sometime
Thanx
Dan
Old Jan 17, 2002 | 02:47 PM
Dans91's Avatar
Car: 91 RS
well camaro6spd are you going to reply, can i use the heads off of an 87 block on my 91, and everything will bolt up just fine????
Thanx
Dan
Old Jan 17, 2002 | 03:12 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Dans91, I have a set of 305 TPI heads I wanna get rid of... They only have about 12k on a rebuild, and the engine ran great b4 i took it out. the valve seals dont leak at all! If your interested, drop me an email! Theyre complete too, with springs, rockers, and valves. I also have a roller lifters/pushrods if you need them.
ws6transamgta@aol.com
Old Jan 17, 2002 | 04:34 PM
87's should be new style centerbolt heads, which is what you need.
Old Jan 18, 2002 | 02:25 AM
Dans91's Avatar
Car: 91 RS
88 WS6 TransAm GTA you got mail!!!!!!!!
Thanx
Dan
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
