LG4 cam choice help
Old Sep 5, 2020 | 09:55 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
LG4 cam choice help
Hi all! Wanting to replace the stock cam in my LG4. Car is only driven on the weekends for cruising. Looking for something a little lumpy.
It's an 85 block out of a T/A with stock heads. Edelbrock Performer intake and 1406 carb. Headers with 3" exhaust. Manual trans.
Would the XE262H (link) be too much?
I should do springs as well, Comp Cams 981 right?
What about lifters? I should see if there's a cam kit with that cam.
Old Sep 5, 2020 | 10:41 PM
Re: LG4 cam choice help
262 is too much for an otherwise stock LG4.
Remember, there's no such thing as "too much cam"; only, "not enough motor".
The LG4 falls into THAT category.
The XE256 is a WONDERFUL match to a stock LG4. Resist the temptation of "lumpy". It leads to soggy bottom end (EEEeeeeeewwwwwwww), no leave, the Venus of Lespugue (yeah look it up) with steatopygia in a minivan humiliating you at traffic lights, and ... it just kinda goes downhill from there. DON'T.
Old Sep 6, 2020 | 06:48 AM
Mortorq's Avatar
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
Well Sofa,
That certainly was quite an accurate well researched gross graphic analogy lol🤢
You never fail to deliver!
Old Sep 11, 2020 | 08:20 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
lol good to know you're still on here for my dumb engine questions sofa. thanks for the reply.
How much more aggressive over the stock LG4 cam is the XE256?
Old Sep 11, 2020 | 11:40 AM
The stock LG4 cam is the beloved "peanut" cam. It's something like 190°/194°, .375"/.390". I don't recall the exact specs but it's somewhere close to that.
Old Sep 14, 2020 | 05:31 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Oh my, OK so the XE256 is quite a bump over those numbers!
Old Sep 14, 2020 | 10:21 AM
Yup, a pretty significant bump. The 262 obviously would be even more. It's simply too much for that motor, especially with its very low stock compression, the stock converter, and the stock gears. The 256 works pretty well but really needs headers and complete exhaust, for something OTHER THAN LG4 or L03.
Old Sep 14, 2020 | 12:02 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The XE262 or even XE268 works well in a 305 with a stick or higher stall converter behind it.
My normal cam for a 305 is a 218/218 @ 0.050, 110 LSA, .454/ 454 lift installed on a 102 ICL. I had the Lunati version in the 305 Vortec in my Tahoe. With the stock converter it was a little sluggish off the line with 32" tall 20s and 3.42 gears but cruised effortlessly and had alot lof midrange and top-end power. I put Rhoads lifters and a S10 converter in it and with more low-end torque and a ~2,500 stall speed it really woke it up off the line. When I swapped the stock 350 vortec exhaust manifolds and cats out for long tubes, dual 2.5" pipes to the muffler with high flow cats it gained power everywhere. A Volant cold air intake for a Vortec truck and later model electric fans also added to the power. What did the 4L60E in on that Tahoe was a 75 hp dry shot into the MAF. 75 hp dry shot gave about 100 hp. I think some of the extra power came from intake charge cooling as the evaporating nitrous chilled the whole intake path.
That being said the LG4/L03 love a small shot of nitrous. In that application a wet shot is necessary.
Old Sep 14, 2020 | 12:57 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I used a Summit K1103 cam kit IIRC on an LG4 once and it perked it up a good bit. Used stock springs. That along with headers and a 650 Holley improved the car a full second in the 1/4. Looking back a lil stall converter and some gears would have really helped that combo.
Old Sep 14, 2020 | 02:05 PM
Monteman71's Avatar
Car: 1986 Iroc Z28
Engine: 305 LG4
Great info here,
Can stock springs be used with the above mentioned cams?
Shawn
Old Sep 14, 2020 | 02:10 PM
No. Stock springs are hardly even good enough for stock cams (upgrade some sometime and you'll see what I mean).
Well, not if the intent is to have a successful build that drives more than it gets worked on, anyway.
Old Sep 14, 2020 | 02:33 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Im sure I put new springs I think they were just run of the mill Z28 springs nothing special.. I would consider those stock I guess. For my Vortec build I used Alex Spring kit. When we put an engine together they have all been "succesfull" they don't have to be worked on other than changing oil Lol. That 256 cam is only a tick over stock.
Old Sep 14, 2020 | 05:04 PM
"Z28" springs may be "stock" or at least "stock replacement" for SOMETHING, but they're not stock for a LG4.
The XE cams are CONSIDERABLY more aggressive than stock, peak lift notwithstanding. There's ALOT more that goes into spring requirements than just the peak lift #. Mostly, how steep the ramps are, which determines how hard the valves are to control; especially when they slam back onto the seat when closing, and bounce. That's just about the worst thing that can happen in a motor; it DESTROYS parts. Good springs prevent that kind of damage.
Old Sep 14, 2020 | 05:52 PM
theraymondguy's Avatar
I’ve been looking at plausible cams for the LG4 for the entire summer and have read at least each related post twice, and am torn between two either the L82 or summit 1103 due to the 700R4 with standard converter. My 1985 LG4 should be the 9.5:1 variety with 416 heads. I have 2.5” headers and an old school Edelbrock 2101, standard q jet, 700R4 and 3.27 axle.
From what I’ve read, the exhaust flows about 65% of the intake on the 416 head, so I’m inclined to look at cams with more exhaust lift/duration to even things out.
Whichever I choose I will be doing new springs, but which to choose? I’m thinking the VSA3 / ERV943 would do? Just life everything off that’s present and install the new springs - I am stumbling across some posts indicating there is some sort of spacer at the base of the spring? I’ve done valve seals on these heads and did not see this?
Old Sep 14, 2020 | 06:55 PM
NoEmissions84TA's Avatar
You don't have to buy from Alex, but look at this for INFO. Pay attention to the notes!
https://www.alexsparts.com/sbc-z28-v...bc-iron-heads/
BTW, for anyone with an LS engine, Alex has CompCams TITANIUM retainers on clearance right now: https://www.alexsparts.com/comp-cams...prings-754-16/
Old Sep 14, 2020 | 07:30 PM
thank you, that’s what I needed to see!
rotators I understand have a different appearance than the standard retainer, I noted this when I did the valve / umbrella seal replacement.
Old Sep 15, 2020 | 10:54 AM
Monteman71's Avatar
Car: 1986 Iroc Z28
Engine: 305 LG4
Hi again,
So,if I understand this,an LG4 cam change will require sourcing valve springs,shims,measuring lengths,even machining?
Shawn
Old Sep 15, 2020 | 01:48 PM
Shims & measuring, yes.
Machining, no.
It's really not too hard at all. Plus, if you're doing a cam change, odds are you'll want to change the timing set too; you can get a kit with all that stuff in it, all at once. Might have to buy shims separate and of course a spring height mic. You can "rent" a spring compressor at your local parts store. Good idea also to put new seals in at the same time. For the seals, don't bother with the O-rings, or "umbrella" type. Use only "positive" type.
https://www.summitracing.com/parts/cca-k12-234-2
https://www.summitracing.com/parts/cca-4754
https://www.summitracing.com/parts/sum-900032
https://www.summitracing.com/parts/fel-ss72861/make/chevrolet
Those springs should be set up at 1.70" if memory serves. Since you're not trying to max them out, getting each one to anywhere between about 1.69" and 1.70" should be plenty good.
Old Sep 17, 2020 | 06:02 AM
Machining, no.
https://www.summitracing.com/parts/f...make/chevrolet
Thanks Sofa, that’s gold.
dbtk2
Jul 2, 2006 08:10 PM
88_Import_Slaye
Jan 6, 2005 02:08 PM
Kevs87TA
Jan 17, 2003 01:02 PM
Berlinetta
Carburetors
Feb 12, 2002 09:42 PM
