need some cam help/advice for SR 383
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
I am building a 383 planning on AFR as cast heads and have already in hand a GM hot cam 218/228 .525" lift and was looking and found a Comp 280xfi and wondered if that would work with a Super Ram that I have planned I also have the E4 PBL? piggy backed to ECM Sorry I'm not big on tuning so I plan to take it to someone that can do it right. is the comp too big car will be manual with 3.54 gears thanks in advance guys
Transmission: T-5, TH350, T-5
Re: need some cam help/advice for SR 383
Ebl-p4? And no it's not too big.
Car: 90 Formula 350
I do not have experience with it in my own vehicles, but it is a common cam in a 383 combo. If you want a smoother idle then stick with your current cam.
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Should run great. I have the xfi292 in a manual trans 383 and don't hesitate to drive it anywhere. Zero adverse affects. The 280 should be a great match to your combo.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
if yer on the street only you'll love the 280, but the 383 will swallow a 292 no probs, you'd love that one even more (only MO)
