91' TPI 5.7 Driving fine then sputters and dies MAP Code 33
Old Jan 14, 2021 | 10:16 PM
Shinobi'sZ's Avatar
Car has been driving great then all of a sudden sputtered and died. Starts back up drives fine and then intermittently fails again. Pulled codes got a the normal 12 code that checks ECM, then immediately following 33 which shows as a MAP. I replaced the MAP sensor and it does the same thing. Any other sensor in the loop that would cause that code to throw or is it the ECM failing? Car starts afterwards and drives fine....really intermittent but got the same code twice now with two different MAP sensors.
Once thing I didn't do is disconnect the battery after replacing the MAP sensor, so I suppose it could be an old code. But no other codes.
Old Jan 14, 2021 | 10:25 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91' TPI 5.7 Driving fine then sputters and dies MAP Code 33
https://web.archive.org/web/20200703...vythunder.com/
Old Jan 14, 2021 | 10:31 PM
Shinobi'sZ's Avatar
Thanks I ran down the troubleshooting guide and noticed something. Since it is a new MAP sensor and the harness is in good condition I will check the vacuum hose. It did seem like the end of the vacuum line that goes over the inlet to the MAP sensor from the intake was wasn't tight and kind of flared out at the end.
Randy_M
Aug 15, 2011 10:34 AM
timonator
Jun 17, 2010 04:54 PM
joebeagle
Jun 16, 2010 06:19 PM
88fbird
Apr 7, 2006 09:19 PM
Pino91Formula
Jan 31, 2001 08:21 AM
